CLOCK RESETS TO THE WRONG TIME
Although we are following the manual carefully, the clock on this unit keeps resetting overnight to the incorrect time. Help!
  • 244 Answers
Check to see if the date is correct
Posted on Sep 23, 2009
Alarm clock time keeps resetting
Download the manual here: http://www.manualslib.com/manual/1056350/Ge-7-4809.html
Dec 08, 2013 | GE 7-4809 Clock Radio
Jeep liberty clock reset
I think you have a loose cable for the memory
Mar 26, 2013 | 2009 Jeep Liberty
Jandy controller shows incorrect time
go to time set set time and date make sure there is a battery in aqualink or when power goes out it resets
Jul 25, 2012 | Jandy AquaLink RS2/6 All Button Dual...
Radio resets when car is turned off
There is a yellow wire in the harness coming out of the head unit, this should be connected to a constant power. This circut maintains power to the head unit for the clock and memory.
The red wire should be connected to a source that is turned on and off with the key switch.
Jun 01, 2010 | 2003 Ford Focus
Car clock won't keep accurate time. I keep
OK now you sized it down the ignition on it lights the numbers but the unit needs the power from the battery and that has to be seperate and direct wirh some type of fused protection. Just like if you had the battery out or dead everything resets to its origin.
Always had to reboot a computer in the old days... Now a days it is our cars Tommy Tech the Wreck
Jul 29, 2009 | Electronics - Others
Honda VFR800 Fi 2000 W Reg LCD clock problem
The problem is usually a weak battery. When cranking, it pulls down the system so much that the clock resets. Try puting the batt on a charger and start the bike to see if the clock resets with a steady feed of voltage.
May 17, 2009 | 2005 Honda VFR 800
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Clock adds 1 hour overnight
There's no downloadable manual, but the manufacturer has it on a page here. As for the time changing overnight, make sure you have the right time zone set. It's probably wrong now, and the clock is resetting itself each day to what it thinks is the right time.
Apr 01, 2009 | SkyScan 86709 Atomic Wall Clock
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
WHEN PRESSING COOK TIME OVEN CLICKS ON FOR ONE SECOND AND RESETS CLOCK
Please try on some other power point as if there is loose contact or sparking in point which cause to switch off as soon as you start because of heavy current drawn by oven and clock also resets. If not solved even then must have some short circuit or over loading in timer circuit or magnetron. in this case you have to call for a service engineer.
Jul 26, 2007 | GE JVM1860 Microwave Oven
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
