Question about InFocus ScreenPlay 61" Rear Projection HDTV
Blank screen When i plug the tv in the blue touch lights light up and the tv "clicks" and sounds on but the power button does nothing. The screen stays black. The remote does nothing as well. The tv was moved but very carefully! the power cord has had the ground removed but was set up that way and working for 2 yrs.
  • Voodoo00 Apr 27, 2009
    I have this same problem - tv has been working well for years. Now, there is no picture (not even the menu boxes - nothing) and no sound. When I plug the TV in, you hear a click and the blue lights on front come on and stay on. Any suggestions?
Mine was doing this for a while and now is completely black all the time. I have a thought as to what this might be... I believe the problem is not the lamp or light engine but rather one of the brushless fans failing. This causes the tv to shut down as a safety measure because of the inability to purge the heat that would build up VERY QUICKLY and warp, damage and destroy everything else. I believe the problem being intermittent at first is due to the fan performing a "death rattle". The fan itself could be fine and more of an indirect problem. I believe the wiring coming out of the fan is inadequately insulated against the heat generated. It begins to cook, crack and eventually the bare wires touch causing a short or they just stop conducting altogether and fail.
The good news? You may be able to re-wrap the wires and be up and running again. If the fan needs to be replaced altogether, they cost about $15 and can be purchased on the internet. Nothing special about them. You would want to make sure it has the same leads coming out of the fan to facilitate the change-out. Again, I haven't attempted to install a new fan on mine yet but it will be the first thing I try.
If any of you attempt this before I do, please post your resulting experience for the rest of us. I will do the same. Good luck.
Posted on May 04, 2009
  • 3 Answers
More than likely your lamp is dead. The only way to get one of those is to send it out for replacement (i.e. you have to actually send out your light before one will be sent back to you.) The cost varies widely between approx $600 and $250 plus s/h. If you go on ebay, you'll find several vendors.
On the same topic, this maybe due to the TV being left on for a while, turned off, and turned back on at which point either the electronics on the lamp or the bulb itself become damaged. The clicking and whirling you may hear is probably the fan coming on and turnign off.
Posted on Feb 24, 2008
Dell xps touch sreen just blinking blue light but blank screen
Sounds like it went to sleep due to low battery power. May be time for a new battery if it isn't holding charge well.
Plug it into the wall and push the power button once. It may come back on. If not...
Hold the power button down until the machine shuts off completely. If that doesn't work, remove the battery.
Feb 04, 2015 | Dell Computers & Internet
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
Blank Screen
If it has sound, then its back-light has failed which is a service engineers work but may also be related to a screen fault in which case a new set is needed as cost of repair makes it not worth it.
If no sound then dare I say worse and mostly if more than 2 years old, not worth it, sad to say as parts do not linger very long other than major brand names most are generic badges on economy sets.
Hope this helps..........
Nov 24, 2017 | Vizio vm190xvt 19 in. TV
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
My 42 inch philips (42PFP5532D) has blank screen but blue light to show its on but nothing on screen :(
just let me know if their is a sound when you turn on the tv then the only problem is black screen. if you can get sound tried to press the channel up/down button let see if you can get a channel. if you hear that receive channel that was mean the problem is either the screen back light get busted or the power inverter is defective. hope this can help good luck.
Nov 02, 2012 | Televison & Video
Blank screen Samsung LN-R409D, audio when turning on and off and blue light at power button in on position???
Hi there
Im afraid this sounds like a fault with the TV. Try turning it off at the wall for 3 minutes, and then with nothing plugged into the TV, turn it back on. If the problem persists contact the manufacturer.
Hope this helps
TV_Doctor
Jan 03, 2011 | Samsung LN-R409D 40 in. LCD Television
Press power, buttons light up and thats it
Try pressing the clean cell now button & check pre filter button at the same time hold buttons down at the same time for about 5 seconds with the air cleaner turned of and blue screen lit
Jan 30, 2010 | Kenmore AC2044-1 Air Purifier
SANYO DP26647 blank screen, please help
U have LED front power tv light come on and bliking?Than ur power suply it dead.Power supply board must be replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Sep 21, 2009 | Sanyo DP26647 26 in. LCD TV
Blank Screen
Same Problem. I fixed mine with a baseball bat, hammer, and a cold beer. Lesson learned: NEVER BUY DELPHI AGAIN. NEVER..... Tell your friends. Delphi = POS
Aug 10, 2008 | Delphi NAV200 GPS Receiver
No picture on screen
MYGR8-YOU HAVE TO LIST BRAND NAME AND MODEL #. JOE TV
Nov 30, 2007 | Televison & Video
InFocus ScreenPlay 61" Rear Projection HDTV Logo
314 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
