NO REVERSE ON TRANSMISSION
It
can be issue with gears or problem with transmission and needs to be rebuilt.
Also get the tranny fluid checked. If it's low, then such problems
occurs.
To
troubleshoot these types of issues, check the actual solved problems with these
types of issues.
There
are solved help links provided below: -------
Click
the link below and go through the details and diagrams to troubleshoot the problem:
2003 Lexus RX300: Transmission Fluid Burnt Brown and not
Shift to reverse?
http://whatisbyme.blogspot.in/2012/05/2003-lexus-rx300-transmission-fluid.html
2007 Chrysler 300: Transmission Stuck in Park?
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
1996 Toyota Corolla: Transmission Shift Interlock will not
Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
CV AXLE stuck in Transmission?
http://technoanswers.blogspot.in/2012/04/cv-axle-stuck-in-transmission.html
Transmission in reverse, acts like it's in neutral?
http://schematicsdiagram.blogspot.in/2012/04/transmission-in-reverse-acts-like-its.html
Delayed shift and harsh Shifting?
http://schematicsdiagram.blogspot.in/2012/04/delayed-shift-and-harsh-shifting.html
Dodge neon wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Dodge Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Dodge manual transmission will not go in reverse gear?
http://technoanswers.blogspot.in/2012/02/dodge-manual-transmission-will-not-go.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
1998 Dodge Ram: Not Shift To Reverse?
http://schematicsdiagram.blogspot.in/2012/06/1998-dodge-ram-not-shift-to-reverse.html
Transmission leak on Toyota?
http://schematicsdiagram.blogspot.in/2012/02/transmission-leak-on-toyota.html
Automatic transmission, with no reverse?
http://howtobyme.blogspot.in/2012/02/automatic-transmission-with-no-reverse.html
No Movement When Transmission is Shifted to Drive or Third?
http://schematicsdiagram.blogspot.in/2012/03/no-movement-when-transmission-is.html
While going in reverse mode Fuse number 27 blows on Ford
Ranger?
http://howtobyme.blogspot.in/2012/02/while-going-in-reverse-mode-fuse-number.html
These will help.
Thanks.
