Question about Kenmore Elite 45986 Front Load Washer
F11 appears and will not continue washing. It beeps and the door will not open.
    President:
  • 1,776 Answers
This code indicates a serial communication error, meaning communication between the central control unit (ccu) and the motor control unit (mcu) cannot be sent correctly. Check the wiring harness connections at the CCU and the MCU. Unplug and reseat and make sure there is no corrosion. It can also indicate a problem with the door lock relay on the control board, a faulty hall sensor, or the mcu or ccu themselves. I think that I'd recommend getting an appliance tech to take a look at it, but try the unplug/reseat electrical connections fix first. Very sorry for your trouble. Hope this helped and best wishes.
Posted on Sep 23, 2009
  • Bruce Canfield
    Bruce Canfield Sep 23, 2009
    Remember to unplug the machine from the power source before attempting any repair. Best wishes.
ADL348 is constantly beeping and does not complete cycle
If it beeps continuous and starts on the rinse cycle,then this is indicating the control board is bad and needs to be replaced. NOT THE TOUCH PAD, but the control board.
Dec 17, 2013 | Dishwashers
Cabrio washer wtw6600swz
sounds like you have a door lock problem call a service company
Jan 30, 2018 | Washing Machines
Dr error message
Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My washing machine will lock the door, start the cycle and within a minute, it will start beeping and flash an F, then an 11. At this point, I will hit the cancel button to break the cycle. Sometimes,...
The F11 error code is a communication failure between the 2 control boards. This includes both boards & the wiring harness as potential defective components. However, this is usually the main machine control board that needs replaced.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does f 11 indicate. The wash gets to the end of the cycle but F11 then appears and the door will not open.
F11 - Pump cannot be activated
f11 lights 1&3&4, pump/draining error
this means an open circuit pump or fauty pcb
Nov 28, 2010 | Hotpoint Aquarius WD640 Front Load...
I can't change the default wash cycle without it switching
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 28, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing machine not starting
Jan 03, 2009 | Washing Machines
Check water supply error F11
pump cannot be activated:check pump , connections and wiring
Sep 12, 2006 | Hotpoint Ultima WD72 Front Load...
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
