Question about Linksys Wireless-G WRT54G Router
Ping When I go to administration>diagnostics and try to do a ping I do not have aby success???
  • judgelandis Dec 15, 2007
    I tried google.com, yahoo.com, and msn.com....All pinged properly when I usedthe DOS prompt. Nothing happens when I try the ping under diagnostics for the WRT54G
  • judgelandis Dec 22, 2007
    I don't think my problem has been addressed... I would appreciate a suggested solution...JudgeLandis
    President:
  • 317 Answers
Who are you trying to ping?
Try pinging google.com, their ip is:
64.233.167.104
Posted on Dec 15, 2007
My laptop cannot connect to the Internet although there is full Wifi,can I get help with that ?
If your OS is Windows
Start
type in search program and file
cmd
right click cmd.exe
select Run as administrator
type in ping www.google.com
press enter
if you get a similar response.
C:\WINDOWS\system32>ping www.google.com
Pinging www.google.com [203.184.8.30] with 32 bytes of data:
Reply from 203.184.8.30: bytes=32 time=23ms TTL=60
Reply from 203.184.8.30: bytes=32 time=36ms TTL=60
Reply from 203.184.8.30: bytes=32 time=28ms TTL=60
Reply from 203.184.8.30: bytes=32 time=19ms TTL=60
Ping statistics for 203.184.8.30:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 19ms, Maximum = 36ms, Average = 26ms
then type in the following
ipconfig /flushdns
you should get the following
C:\WINDOWS\system32>ipconfig /flushdns
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
You should be good to go
Aug 29, 2016 | Acer Computers & Internet
Pingtest.net
I will help you to know what is Ping!!!!
Ping is a basic Internet program that allows a user to verify that a particular IP address exists and can accept requests.
Ping is used diagnostically to ensure that a host computer the user is trying to reach is actually operating. Ping works by sending an Internet Control Message Protocol (ICMP) Echo Request to a specified interface on the network and waiting for a reply. Ping can be used for troubleshooting to test connectivity and determine response time.
As a verb, ping means "to get the attention of" or "to check for the presence of" another party online. The computer acronym (for Packet Internet or Inter-Network Groper) was contrived
to match the submariners' term for the sound of a returned sonar pulse.
Tip: To find out the dot address (such as 205.245.172.72) for a given domain name, Windows users can go to their command prompt screen (start/run/cmd) and enter ping xxxxx.yyy (where xxxxx is the second-level domain name like "whatis" and yyy is the top-level domain name like "com").
You can check the ping test in http://pingtest.net/ also you can check that here www.whoisxy.com
Nov 20, 2011 | Computers & Internet
What is Gateway Ping
Ping is used to check for a network path to a specific host. In this case the script will ping from domain.com to the host you provide. Ping should be the first TCP/IP diagnostic tool you use when tracking down a network problem. Ping uses a series of Internet Control Message Protocol (ICMP, often-pronounced eye-comp) messages, that produces an Echo message to which every host responds. When Ping uses the ICMP messages and replies, it can determine whether the other system is alive, and also compute the round-trip delay in communicating with that system. So Ping can show you how fast the connection is between two ip addresses or domains.
Oct 11, 2011 | Samsung LA40A550 40 in. HD-Ready LCD TV
My laptop will not connect to our wireless router at work. It says connected, but no internet access.
The laptop might be connected to your wireless router but is unable to connect to the internet
check if you can ping websites
- click on start > Run > type in "cmd" > in the command prompt type in "ping www.yahoo.com"
- if you get 4 replies the problem might be with your browser.
- if Ping fails try typing "ping 209.191.122.70" which is the IP address for www.yahoo.com
- if ping is successful then the issue is with your DNS server. contact your ISP to get alternate DNS
- if Ping fails try pinging the default gateway or modem IP (you can find the default gateway by typing IPCONFIG)
- if ping is successful then there is a problem with your internet provider
Also you should try disabling your firewall and runnning a virus/malware scan
Mar 30, 2011 | Computers & Internet
I have a samsung tv , and im setting up my INTERNET@TV , it ticks off everything but the Gateway Ping ! Please Help
If the Gateway Ping test fails, then your TV is not communicating properly with your Router or Modem.
To resolve this, follow these steps:
  1. Power off your TV, Modem, and Router.
  2. Unplug the power for your Modem and Router.
  3. Make sure the ethernet cable is securely connected to both your TV and your Router or Modem.
  4. Plug in your Modem and turn it on.
  5. Plug in your Router and turn it on.
  6. Make sure your IP Address information entered into the TV during the Network Setup matches the information from your Router or Modem.
  • If you are using an Automatic Setup (most users), skip this step.
  • If you are using a Manual Setup (advanced users), contact your network administrator to determine what the correct IP Address information is.
7. Run the Network Test again.
  • If the Gateway Ping test passes, but another test fails, click here to go back to the list of Network Tests.
  • If all tests pass, the TV is successfully connected to your network.
  • If the Gateway Ping test fails again, see below....
If the Gateway Ping test fails again, there may be a problem with your network setup. To determine if there is a problem with your network, follow these steps:
  3. Connect your ethernet cable directly to the TV and Modem.
  5. Power on the TV and run the Network Tests again.
  • If all tests pass successfully, then there is a problem with your Router setup. Contact your network administrator or router manufacturer for information on setting up your network.
  • If all tests do not pass successfully, there may be a problem with the TV. Connect another device (such as a Computer) directly to the modem.
  • If the other device connects to the internet, then the TV will require service. Click the Create online service request button below to have the TV repaired.
  • If the other device does not connect to the internet when directly connected to the modem, then there may be a problem with your modem. Contact your Internet Service Provider for help on troubleshooting your modem.
(from Samsung support)
Hope this helps. -Sa_Les_Ski
Feb 28, 2011 | Televison & Video
I cannot access my internet or download. Previous
Check in command prompt if u can ping websites ,check IP address . Ping www.google.com in command prompt. Do ipconfig /release and then ipconfig /renew.
If u can ping google in command prompt issue with Internet explorer try different browser.
Aug 17, 2009 | Computers & Internet
Cannot connect although plugged in
Check the ipaddress. Type ipconfig in command prompt. Then ping a website in command prompt if u get proper ip address e.g 10.132.147.121. Try to ping www.google.com in command prompt. If u are unable to connect. Tried to release renew Ip address.
Type ipconfig /release then ipconfig /renew in command prompt. If you are able to ping google and still unable to connect to website using internet explorer, then issue with browser or with OS.
Aug 17, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Lan connectivity problems
Ping yor pc with ping 127.0.0.1. If this fails, your nic is faulty. If pincs successfully, ping the extneral hardware on your lan to test what exactly cannot connect in your LAN.
Apr 18, 2009 | HP Compaq d530S PC Desktop
I am having problems connecting to a lexmark 4800 printer using wifi on one laptop. it only works through usb. uninstalling and re-installing drivers/software has no success. printer works fine on other...
check your windoes firewall and antivirus firewall .
also check ping to your network printer.
try to ping those ip if u get ping then it is ok.
check your printer and laptop gate way is same.
run this command in "run" iss "ping 192.168.15.1" ehchange your printer ip in this command.
thats it.
Nov 09, 2008 | Lexmark Office Equipment & Supplies
Cannot "ping" 192.168.1.1 (default gateway)
1) yes, referring to the router's IP address.
2) I determined the IP addresses of all my computers and tried to "ping" them but could not "ping" any of them. I can "ping" the IP address of the computer I am working from but I don't think that helps in TS this situation.
3) I'm wondering if my router is fully set up correctly. Do each of the computers have to be "saved" in the router's settings?
Jan 11, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
Linksys Wireless-G WRT54G Router Logo
157 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
