Question about Acer Aspire 3000 Notebook
Video playback stutters is choppy when the video plays it stops and stutters on a frame. it will play for a few seconds then stutter.
  • 379 Answers
I had a problem similar to this and eventually traced it to the wrong mode setting on the DVD drive's transfer mode.
To check the setting, open Device Manager and then double click on the IDE controllers item. Double click on IDE channel (if there's more than one you'll need to check each one) and then select the Advanced Settings tab. On this tab should be up to two devices and each should show under "Current Transfer Mode" soemthing including the word "DMA".
If any device shows "PIO", then this is probably the problem.
If you Google "PIO versus DMA", one of the top results has a really good article on why this happens and how to force Windows to revert to DMA.
Posted on Sep 23, 2009
When I try to view a video online, Realplayer tries to install on my computer, but it's already the newest version. So I can't watch the video. What's up?
We'll to override this you could download adobe flash player which will then ask to go default player.adobe usually has the best updated codecs for online browsing.you need at least 2gb memory to cope with hd playback and make sure all other running programs are shut down whilst online browsing videos.if you are watching stuff on computer a good all rounder which is also free is GOM player.plays just about everything without stutter or choppy playback.
Aug 29, 2014 | Computers & Internet
Clicking noise
Anything with a cassette in it has belts and capstans, play heads and runner rollers. The belt is likely stretched and sticky, replace it with a new belt. I use a product called rubber renue on the roller to stop it from sticking to the tape.
Oct 19, 2013 | JVC GR Video Cameras
Movie playback is really jittery?
Try using VLC media player to play your content.
May 03, 2013 | GoPro Digital Hero 3 Digital Camera
Picture/video is choppy/stutters when playing. Kind of like it's jumping from frame to frame
clean the laser using a lazer disc cleaner not only does the disck get dirty but the lazer too when its too dirty it wont read the disc -- disc error
heres a piture of one you get them from electronics shops
Jan 02, 2011 | Sony Televison & Video
I just bought my laptop from walmart..i dont know how or if i have set it up properly..but when i play a video like on utube it just plays seconds of it and keeps running like its tryin to load.. what can...
If it is playing Video files offline ok, then it sounds like you are suffering from Buffering.
When your connection speed is not fast enough to download faster than it takes to play it. The video stops or stutters. You can press pause and wait for the buffer to fill before you press play.
You can sometimes adjust the settings to buffer for 30 seconds before playback starts.
The only solution is to get a better internet connection.
Check Speedtest.net and check your connection speed.
If it is no where near what you are paying for, you may want to ring your ISP and complain
Aug 05, 2010 | Computers & Internet
I just got my Xacti CS1 and after I shot a couple of test videos, I checked the playback. On the camera screen, playback is flawless, it's quite great, however, when I play the videos back on my macbook in...
http://us.sanyo.com/dynamic/product/Downloads/VPC-CS1_OM_English-6223243.pdf
p.60 of the manual describes different recording modes with lower resolutions (1280x720) pixels and lower frames per second (30fps).
I would choose from the menu to record in a lower resolution and lower fps mode so that the quicktime program can display the video at a good rate for you.
I don't know what kind of macbook you have, but usually such problems are due to the older macs not having enough speed to display high definition video with all its data all at once.
I used to have problems a few years ago, before i upgraded my hardware on PC's, with choppy video that was High Definition.
Jul 30, 2010 | Cameras
Stuttering videos on you tube
It's because the video isn't downloading fast enough. When a video starts playing just hit the pause button ( || ) and do something else for 2 or 3 minutes or so. When you come back, you will see that the red line has advanced most if not all the way to the right. Then hit the play button ( > ) and your video will play without stuttering or freezing.
May 13, 2010 | Computers & Internet
Flip Video Ultra HD MP-4 files playing VERY choppy on my PC
Daniel is a little mistaken with his solution. The resolution of the video is much higher than the little video screen. Stuttering play back has nothing to do with resolution but FPS or Frames Per Second.
Since the video on the little screen is smooth the video should be smooth on your computer as well, just blurry if the resolution is low. However, I am having the same problem with mine and the picture is sharp on my 1080p laptop screen but only appears to stutter instead of playing smoothly.
The camera has dedicated hardware playing it back. This is also the same hardware that is encoding it while recording. My guess would be that the hardware encoding is using a faulty codec that is not playing back well.
Aug 02, 2009 | Thomson Lyra PDP2860 Digital Media Player
Canon Powershot SD1100 IS video problem
I would update your audio and video codecs in the computer. There's the source of the stuttering on playback.
Jul 12, 2017 | Canon PowerShot SD630 Digital ELPH / IXUS...
Samsung s730 Digital Camera - Video Stuttering Problem
I have the same problem with 640x320 video @ 30fps. The first one was very clean, but after that the video freezes every two seconds, but the audio don't. I "fixed" this issue changing the video format from NTSC to PAL. Now the videos are smooth again, and if you want NTSC playback, just use a video converter on your PC.
Jun 24, 2008 | Samsung Digimax S730 Digital Camera
Acer Aspire 3000 Notebook Logo
280 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
