Question about GE Spacemaker JVM1640SJ Microwave Oven
Making a humming noise when turned on and not cooking. I punch in the cooking time I would like and then when it turns on it makes a humming noise and does not cook.
  • 2,200 Answers
From your description it appears that the Magnetron has failed on your microwave.
*Please be aware*
Replacing the Magnetron in a Microwave is a highly specialist job and should not be carried out by an unqualified person. Microwaves carry lethal levels of voltage even after they have been unplugged from the mains supply. The high voltage circuitry in this area of the oven is extremely dangerous and must undergo a discharging process before work can commence. The Magnetron itself is the main 'engine' of the microwave and operates under extremely high voltages.
For this reason I strongly urge you not to attempt this repair yourself but have it carried out by an electronics repair shop. The cost of this is likely to be prohibitive and you will need to weigh up whether this repair is economically viable or whether you would be better to replace the unit altogether.
Hope this helps. Thanks for using FixYa.
Posted on Sep 23, 2009
  • 388 Answers
That humming noise is the magnetron failing. Replace the magnetron and you should be good to go.
Ge micorwave JNM7196 making humming noise
Could you post the full model number from the tag on the wall of the cooking cavity?
And when does this hum occur? Is it when it's setting still plugged in but not operating, or only when it's cooking, or only when the door is open?
Contact me at microwavecontrol.com if you prefer. I'm happy to give free advice.
Jan 22, 2017 | GE Microwave Ovens
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
Frigidare microwave has humming noise when not in use
You have a shorted cook relay.
Apr 26, 2013 | Microwave Ovens
Frigidaire microwave plmv168cc1 makes humming noise when door closed
Chances are that the secondary (cook) relay on the control circuit board is shorted, meaning that the oven is actually cooking any time the door is closed.
You can test that by putting in a cup of water, shutting the door, and letting it go for about 30 seconds, then checking the water temperature.
This is dangerous, and can lead to a fire, so please unplug the oven until it is repaired.
The relay can be replaced for far less than the cost of a new control circuit board.
May 31, 2012 | Frigidaire Microwave Microwave Oven
GE microwave model number JVM230WV 001 popped while cooking now when turned on it will only make a humming noise. Light comes on but no heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns on but it makes strange noises and does not cook anything. After a little while I get an error message that says something like cooking sensor has timed out
So we can help you, please post a NEW question, and please include your full model number from the tag in or on the unit, as well as the answers to these questions:
When you try to microwave are the inside light, internal cooling fan and turntable all working?
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 11, 2009 | GE Microwave Ovens
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave problem
Is this a new or used unit, and is the humming sound new? Can you watch the fan blade go around or is it going too fast to watch a blade?
Feb 14, 2008 | Maytag MMV1153A Microwave Oven
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
290 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
