Question about Frigidaire FRS26R4A Side by Side Refrigerator
Frigidaire fridge leaks where ice maker is on
I have a Frigidaire stainless steel side by side door. When I switch on the ice maker, the water drips drop by drop at the (front) right side of the fridge. Friends suggested that there could be a leak in the pipe of the water connection. When, I took a look at the rear of the fridge I saw few inches of water on the base of the fridge. All the coils were immersed in the water. Please suggest what could be reason and is it fixable.
  • Frigidaire Master
  • 4,655 Answers
Your leaking problem gives two possibilities. The water control valve for the ice maker side is defective and while shut off the water will continue to slowly flow and leak into the freezer compartment. The other possibility id the condensate defrost drain is blocked and frozen over behind the rear panel of the freezer and at the bottom of th coils. I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Posted on Sep 23, 2009
How do I shut down the water flow to the ice maker
There are three ways.
1. Shut water off to the fridge via plumbing valve.
2. Lift arm on ice maker or use on/off switch depending on ice maker model.
3. Unplug ice maker wiring harness. It won't be able to call for water.
It depends on why you want the water off. A make and model of the fridge would help so I can give you a more specific answer.
Apr 05, 2016 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a Frigidaire professional side by side fridge model# LPHS2687KFO water is leaking before entering ice maker thus the ice maker is not working, water is leaking in freezer
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Apr 25, 2011 | Frigidaire Refrigerators
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
May 15, 2017 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Ice maker does not make enough ice - it doesn't fill up the bin
check for water in ice maker with finger and if no water check water connection and water valve in back of fridg on bottom . you need to pull panel and check valve and water make sure it is on and not leaking...
Aug 12, 2009 | General Electric GFSS6KKXSS Stainless...
Ice maker stop making ice
Check to make sure the the little lever that tells the fridge "ice bucket is full" is not frozen or stuck.
Jul 08, 2009 | Frigidaire PLHS237ZD Stainless Steel Side...
PHS39EHSS Fridgidaire refrigerator leaking.
Ice makers making grinding noise. This happens every month. What we do is unplug the fridge remove all the food in the freezer then use a blow dryer to thaw the ice build up (fan?)This is very annoying and I would like to find a permament solution. Ibought Frigidaire Professional because I thought I was getting a quality product. I guess I was wrong. Any help I can get would be appreciated.
Apr 28, 2009 | Frigidaire PHS39EHSS Stainless Steel Side...
My ice maker is turned off, but water slowly seeps into the tray
Try turnig off the fridge and let it defrost,keep the doors open and put pans of hot water in the freezer,wait 6 to 12 hrs.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Water leaking from freezer door and ice maker not gettin water
Check the fill tube for the ice maker and make sure it is in the correct place. This sounds like the fill tube has been moved and is running water into the freezer instead of the ice maker. Let me know what you find. I am here to help you.
Nov 12, 2008 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
889 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
