Question about Rockford Fosgate Punch 250a2 Car Audio Amplifier
I have fosgate car audio amplifier, installed, when i connect the left speaker i get music but when i connect the right speaker the music comes out sporatic, what is that caused by?
Shuttle83
  • 1139 Answers
SOURCE: Rockford Fosgate P2502
Hello tejano71, I would suggest that you check your grounding and if possible run an extra ground from the battery ground just to make sure. Then I would use an DC line voltage filter between the power supply and the AMPs. If this does not work. You may have an issue inside of the fosgate AMPs. To troublehoot these you will need a voltmeter (set to the AC setting), audio tone generator (multiple settings from 20Hz to 20 Khz), two dummy speaker loads (set to proper impedance and wattage), and an oscilloscope (to see if clipping is occuring). After you have these items, connect the dummy loads to the AMPs and then connect the ground wire to the AMPs, and connect the power supply to the Amplifiers. Put one of the oscilloscope leads across one of the dummy loads and the other oscilloscope lead across the other dummy load. at this point connect the Audio Frequency Generator and set it to 20Hz and increase it to 60Hz as you also increase volume at each frequency looking at the oscilloscope for any signs of clipping continue to increase as you get higher in frequency. You should see very little clipping. If clipping is seen the actual unit may have a voltage regulator problems. If the unit has voltage regulation problems, I would suggest that you take the unit to a repair shop for further investigation, I have repaired quite a few of these units and for the most part regulation on these items sometimes can go bad with very little warning. Let me know if this solves your problem, or at least points you in the right direction. Thank you, Shuttle83
Posted on Sep 05, 2007
SOURCE: ROCKFORD FOSGATE Punch 301M Amplifier Problems!!!!!!!!!
check the resistance inside the amp ihave one 2 and they actually burn fast....
Posted on Jul 08, 2009
bill_48632
  • 149 Answers
SOURCE: connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Posted on Aug 09, 2009
j_del
  • 1586 Answers
SOURCE: Rockford Fosgate Punch 801X Car Audio Amplifier schematic
You're not going to be able to get that - it's considered proprietary information and won't be made available to the public.
Posted on Apr 30, 2010
evan89
  • 356 Answers
SOURCE: do you know where I can fix my Rockford Fosgate
You could open it up and if you are familiar with soldering that is most likely your problem something that was soldered down has come loose.
Posted on Mar 03, 2011
I just installed a new xo vision x349nt dvd receiver in my car . My rockford fosgate p3001 amp turns on but the subs doesnt come on but when i would take the base control out and put it back in i can hear...
Make sure and check the RCA wires in the back of your radio that send audio to the amp and make sure that they're connected to the OUTPUT/SUBS RCA's and not an input rca's. Also, check your ground and make sure no speaker wires in the subs are shorted. Try one speaker at a time see if that helps.
May 18, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
How do u bridge the rockford fosgate p325.1?
Hello... sorry you are having a problem. If you are running the 325.1, that amplifier is strictly a mono-block amplifier (1 channel) so it is not possible to bridge it. There are 2 speaker connections on the amp but both positives and negatives are connected on the circuit board in the amp. Hope this helps. Good luck with your venture.
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Rockford Fosgate Punch P325.1 Car Audio...
How do you install an amp in new cars when the factory radio is basically an computer and doesn't come out of the dash?
You need to use a Hi Low Converter. They have a different name but I cant think of it right now. Basically it connects to your rear speaker and converts it to RCA connectors that you could connect to your amp. Then connect your amp to power (battery) and Ground to power it up. Last thing to do is connect yours speakers to the amp.
Also get a high Low converter with remote connection.
Apr 22, 2010 | Rockford Fosgate Punch P3002 Car Audio...
How to install a rocksford fosgate power 800a4 amplifier?
you will have to get a amp kit. run a power line from the battery to the am and a remote line from the radio to the amp then run a ground from your car from (scratch the paint off) and connect that to the amp,connect your speakers to the amp.
Mar 23, 2010 | Rockford Fosgate Punch 401S Car Audio...
Rockford Fosgate Spare speaker termal screws
if you have one that you can compare to another, go to home depot with that and match it up. If not, take the amp to home depot and get someone to help you find the right one.
Jan 29, 2010 | Rockford Fosgate Punch P5002 Car Audio...
How do i hook up the amp wires to the factory stereo and the speaker wires
Amp wires are direct to battery..as far as sound, you need a line level converter to connect to your rear speaker wires (left/right) that sends the signal to the converter and switches it to RCA level outputs. You would then just connect an RCA cable from the converter to the amp and there you go. A converter is $20-$50 depending on the quality you want. The better ones connect to pos/neg and have a metal caseing.
Nov 05, 2009 | Rockford Fosgate 800.2 Car Audio Amplifier
Connect rockford fosgate amplifier & speaker together
Aug 09, 2009 | Rockford Fosgate Punch 401S Car Audio...
I have a rockford fosgate 501bd amp the protect light comes on when my deck turns on even with no speakers connected
un hook the subs and let the amp sit there on if the protect light shuts off you wired your subs wrong if it doesnt go off tun it off then back on with no sub music all the way down then slowly turn the music up if the light is off then comes on you need new rcas
May 03, 2009 | Rockford Fosgate Power 501BD Car Audio...
Sep 04, 2007 | Rockford Fosgate Punch P2002 Car Audio...
Rockford Fosgate P4002
Yes they are ! And that means the DC is on the speaker and will for sure damage the speaker if it already hasent
Jun 15, 2007 | Rockford Fosgate Punch P4002 Car Audio...
Car Audio & Video Logo
64 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
