Question about Cell Phones
Samsung SGH-J210 I want to install jad file via usb cable in my Samsumg SGh-J210 Help if any software send the link to me
I have samsung mobile star i want install jad file in to moblie but i am not able to do .. so i need solution
Usually samsung mobiles cant install .jad or .jar files directly. U can install it when you are downloading it via gprs. Try the site http://www.mobilatory.com/ and use its "send to phone" software.
Else try this solution from Yahoo! Im not quite sure it works
  • Go into Settings
  • Scroll down Port window: You should get just one COMxx option. Choose it and press OK.
  • Go to File - Connect. You should get the STAR File System Tree at TkFileExplorer bottom half side.
  • Go to /Exe/Java/Games
  • Create a New Folder for your game
  • AtTkFileExplorer PC upper side select game JAD/JAR files and copy tocreated folder using drag&drop or right button menu Download option.
  • Repeat steps 9 & 10 for all games you want to install at a time.
  • Disconnect USB cable
Dial *#6984125*#
Go to Internals (Master Key: *#9072641*#)
Go to Storage Settings and select Update Java DB
Oct 26, 2009 | Samsung SGH-L700 Cell Phone
Samsung sgh-j210 phone not supported jad file or jar file
it supports jad.but the thing you should do is "use your mobile internet to download the games".www.waptrick.com is the site you can find games for your sgh-j210.
Oct 25, 2009 | Samsung SGH-j200 Cellular Phone
Unable to install software in SGH-L700
SGH-L700: Install Java games
How to install Java games on the Samsung L700 without any software or drivers
In the phone Menu select
'Settings'
Then select
'Phone settings'
Then
'USB settings'
And choose
'Ask on connection'
Plug the Phone in to the PC with the USB cable
On the phone select
'Media player'
Open the folder
'Phone'
Phone memory...
You should see the folders: images, Other files, Sounds, Videos
Create a new folder and name it
Games
Put any game you want to install in that 'Games' folder
Two things need to made sure of when copying over the games. Firstly make sure you have the *.jar and
*.jad files for each game, if you don't have the *.jad file, you can download a jad creator pretty easily, just type it in Google. Secondly each game has to be in it's own folder, if you just dump all the *.jar and *.jad files directly into the 'Games' folder only the first game installed will work (Poorly too).
Now Unplug the phone
Now on the phone dial the code:
*#6984125*#
Select 'Internals' (Number 4)
It will ask for a master key it is:
*#9072641*#
Select 'Storage settings' (Number 7)
Update Java DB (Number 2)
Note: As soon as you do "update java DB", the game will install... no need to run the .jar and .jad files now.
Now your game is installed...
To play the game navigate to My Files > Games and more...
There you can find the installed game..
Apr 18, 2009 | Samsung SGH-L700 Cell Phone
Games Download
How to put games on your samsung
1st - Type in the code *#9998*52824678255#
A message will come up saying activated. Now you are ready to install your java games.
2nd - Download a program called jad maker, because in order to install your java games you need the .jar file and the .jad and most torrents only include the .jar
3rd - Find some compatible java games to download.
You can find many games at: www.getjar.com
4th - Send the .jar and .jad file for the game to your phone, whether via bluetooth or usb cable.
5th - The files will most likely go to your other files folder. Open the .jad and it will install the game for you then ask if you would like to play it.
*Notes*
Each time you turn off your phone you need to re-enter the code.
Some games will simply not work on your phone.
If you would like you can reply with your phone model and list the games that work on that phone
Apr 09, 2009 | Samsung SGH-t629 Cellular Phone
How to install jar/ jad files samsung sgh e250
Mar 03, 2009 | Samsung Cell Phones
IS SGH E840 JAVA SUPPORTED MOBILE
Yes, this phone supports JAVA, to activate JAVA use the code below.TO INSTALL GAMES, follow the rest
Just follow the link below.
*#9998*4678255# punch this code on samsung E840.
You would get the message "activated".
Then install the PC studio that came with the mobile on your PC.
Through PC studio, get conected to the mobile.(use USB connection cable).
Visit the website, http://www.getjar.com/software/Samsung/SGH_E840
download both the JAD and JAR file of t he games or applications on to t he others folder, (to do this, download them to PC and then through PC studio drag and drop them to the other folder on the phone).
Then, choose menu on the JAD file, click install.
This worked on my samsung e840.
Feb 16, 2009 | Samsung SGH-E840 Smartphone
How i install the themes, games in samsung sgh e251 by pc
there was not themes for samsung but you can install games ans application in one condition that you have the jar and jad fils : search in internet ( free downlod java games jar/jad ) and install the jad from yor phone.and that's it
Jan 09, 2009 | Samsung SGH-E251 Mobile Phone - Black
Sgh-e840
i have the same problem and I solved it. first of all pun this code *#9998*5282#. Then put your game (with .jar and .jad) in your phone memory. when you want to install a game press the left button on the jad file. good luck!(sorry for my english ;) )
Sep 06, 2008 | Samsung SGH-E840 Smartphone
Cell Phones Logo
56 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
