Question about Proscan PS27108 TV
Changing channels Hi: I am not able to change channels using the up and down arrows on the remote but I am able to change channels by punching the actual channel number in. How can I channel up and down?
  • 1,694 Answers
Put the channels in memory by selecting CATV and then auto-program in set-up menu...................................T.
Posted on Dec 21, 2007
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
Mintek remote will not change channels. Tried a
See if you can change channels by manually punching them in on your remote. If so, you need to go to your menu, channels and autoscan your channels again. Then you should be able to use your forward and backward buttons again.
Nov 29, 2009 | Mintek DTV-265-D 26 in. LCD TV
Re: Sony Bravia remote problems
sounds like you need to "autoprogram" your channels. In the customer menu search for "settings" (looks like a toolbox) select that, arrow down to "channels" select that, you'll see option for "autoprogram" select that. Any channel it sees it will lock in and you shouldn't have to press numbers anymore.
Apr 27, 2009 | Televison & Video
Run a channel scan on the DTV and/or TV input depending on what one your not getting channels on. This will solve your issue.
Change the input on the unit to the DTV or TV input. Press the menu button on the remote. Navigate to the tuner DTV or TV tuner setup menu. Go down to auto search using the down arrow. go right when with auto search selected. This may take a few minutes but you should have all the channels back after the scan.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Sony WEGA 42" LCD Rear Projection TV It won't change channels up or down with the remote or the buttons on the television.  It will change channels with the number pad on the remote but not the channel...
Hi, it sounds like your saying that punching in 08, 09 etc. works but channel up button won`t switch from 08 to 09 correct??? If so you need to go into your tv`s menu and "autoprogram" your channels into memory, video-tek
Jan 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
Quasar vhq41m
Hi , set remote to auto program set enter /on sreeen will appera then stop if no channel appear ,then select channel.
Jan 21, 2008 | Quasar VHQ400 VHS VCR
Televison & Video Logo
267 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
