Question about HP ScanJet 2200C Flatbed Scanner
After installing the driver and trying to use the scanner, I get an error from the new hardware wizard. The error is "the class installer has denied the request to install or upgrade this device" I am logged in as an admin and the scanner is not plugged in during installation. Any ideas?
    Scholar:
  • 52 Answers
This error may be due to other devices that detects on your computer, it may be a device of mother board hence I suggest you to check device manager for any yellow question mark and then install the driver accordingly.
Posted on Sep 23, 2009
Hi, I want to install both fujitsu fi 5750c and 5530C2 Scanners in same PC. OS is win XP. I tried through setup, but when one is installed, second one's setup says already having Scanner Utility...
There is no need of installing driver for fi-5530c2 scanner as the driver comes bendled in the fi-5750c scanner. Hence, please install the driver for fi-5750c.On the application, you need to chnage the scanner model under "Select Scanner" menu.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jul 27, 2011 | Fujitsu fi-5750C Flatbed Scanner
I am trying to install the HP Scanjet G 3010 and I keep getting an error message: Instant Error 2738 and the download stops. I bought this scanner on 02-19-2008 and am just now trying to download the...
Try this one , connect the scanner to your computer and restart it then a fonund new hardware wizard will come that will ask you to install software of rthat scanner which is detected as a new device attach to your computer , then just put the setup CD for your scanner and let the wizard install it automatically for you..
Hope that helps............
Aug 09, 2008 | HP Office Equipment & Supplies
HP scanjet 8279 displays an error 05 and won't clear. I can't turn the machine off either. I have to manually disconnect the machine from power source to try to reboot it. It turns back on then after a few...
Error code 5 denotes a device failed and requires an arbitrator/administrator. If an installed device requests a resource type and detects that there is no arbitrator, computer users will receive this error code. The arbitrator/administrator redirects the system in a chosen field. It cannot happen if the computer has a firewall or has user restrictions. The administrator does this for security purposes. The system denies admission to other users to protect information and important data.
A user is denied access to some files or program. As a result, the user will not be able to obtain information from certain files nor actions like delete, restore, or edit can be executed.Errors on your system may be caused by invalid registry entries and outdated or corrupt drivers.
Update the driver of the files. Use the click start control panel administrive tools Device Manager scroll to ports(Com<p)+to expand you should see a communication port& Ecp printer port you might see a yellow question mark? right click to uninstall and reinstall the appropriate device. Run wizard in the Add New Hardware in Control Panel
hope this helps
Feb 10, 2011 | HP ScanJet 8270 Flatbed Scanner
Error when Installing Lexmark 8300
Take this link to lexmark and select "auto detect". Your hardware will be identified and drivers installed.
http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
Cannot retrieve application list
Please follow the steps given below to update the scanner driver:
1. Right click on My Computer and select Properties.
2 Click the Hardware tab and select Device Manager
3. Right click on the scanner entry that is displaying a conflict.
4. Select Update Driver from the drop-down menu that appears. The Hardware Update Wizard appears.
5. Select Install from a list or specific location, then click Next.
6. Select the Don't search... option and then click Next.
7. Click Have Disk. The Install from Disk dialog appears.
8. Click Browse and select the Lexmark CD from the Look in drop-down list.
9. Double-click on Drivers.
10.Double-click click on Scan, select the lxbksxp file, and then click Open.
11.Click OK. The following screen appears:
12.Click Next to start the scanner installation.
13.When the installation is complete, click Finish to close the wizard.
Apr 28, 2009 | Office Equipment & Supplies
ACER S2W 3300U Flatbed not "connecting" on Windows ME system.
Go into your device manager to see if there is an error.  If there is don't install the software, instead install the driver first.  I would also try to unplug the scanner from the computer and plug it into a different port and wait for Microsoft hardware wizard to pop up and point it to the cd for the driver.
Jan 13, 2009 | Acer Scan to Web 3300U Flatbed Scanner
"Cannot install hardware. Laserjet 2840
HI,
First you have to check which operating system is used with your product? And download software from here . Then reinstall the printer driver again. After that if you face any problem let us know please.
Thanks
Chittaranjan
Jan 05, 2009 | HP LaserJet 2840 Printer
Trying to install HP C4280, fatal error comes up during installation and will not complete
To install that printer, connect the data cable (Maybe USB?) to the PC and follow the instructions on the "New Hardware found" wizard, then supply the CD that came with the printer and make the wizard look for the drivers there. When the HP install program pops up (Gray sandglass), choose "Decline" or "Not agree" to the terms of the license and continue with the "New hardware wizard" installation.
The printer driver will get installed and none of the HP useless programs.
May 04, 2008 | Office Equipment & Supplies
Problem installing new hardware
Where i can get or download TWAIN DRIVER for CanoScan D646Uex ?
Mar 31, 2008 | Canon CanoScan D646U Flatbed Scanner
HP ScanJet 2200C Flatbed Scanner Logo
160 people viewed this question
Seeker5211
Seeker5211
