Question about Electrolux AWF 1435 Front Load Washer
My Electrolux washer is only 6 months old and the drum has started squeaking. What could the problem be?
    Problem Solver:
  • 6 Answers
NOT Solution - I just bought one last week and it squeaked for me today. Sounded like a belt. As the washer added more water to the drum to soak the clothes, the squeak went away. So not sure if belt slightly out of alignment - hence it rubs or perhaps a roller knob needs adjustment is what I am thinking.
Posted on Apr 03, 2010
My Electrolux from load washer GLTR1670AS0 started making a load banging noise during the high speed rinse out
One or more of the washer drum shocks is broken and or the washer drum bearing is defective and has excessive play.
Jan 28, 2017 | Electrolux Washing Machines
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
My maytag washer model #sav5710aww shakes badly and
if its a neptune front load washer you need new tub lip seal and bearings for the drum as the seal is leaking water into the bearings that hold the inner drum,it will only get worse,you need to remove the inner drumto replace the seals and bearing it takes from 2 to 6 hours depending how hard the old bearings come out of the race
Apr 02, 2010 | Washing Machines
Had a service call 7 months ago on 16 year old Maytag Stack w/d to lubricate drum roller that was squeaking. Squeak has returned. Any pointers on lubricating it myself, or is it worth replacing the drum...
Lubricating the bearings is usually only a temporary "quike fix".
Replace the bearings,and lubricate the bearing shafts with a lithium grease.
Mar 04, 2010 | Maytag Dryers
1 month old electrolux FL IQ cuts off and won't restart
If it is only one month old then you should be covered by the warranty ??
To unlock the door place the drain hose in a bowl until the water comes out, if it wont then try blowing down the hose.
If you hear bubbles inside the machine then dump the hose back in the bowl
Once the water has all ran out switch the machine programmer to "off" and then try the door
May 31, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Noisy electrolux dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
tyu634
Mar 02, 2009 | Electrolux EIGD55H Dryer
WMA22- Machine has started making lot of noise.
Sounds lika main drum bearing problem
As it is only 6 months old, then you should contact service agent.as it will still be under guarantee.
Aug 02, 2008 | Hotpoint First Edition WMA22 Front Load...
Electrolux AWF 1435 Front Load Washer Logo
235 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
