Question about Sony CDP-CE375 5-Disc CD Changer
Sony CD player C305 not playing
Sony CD player not Playing : Will not play. It's a 5 disc carousel player and when I load it, it revolves to each cd and moves to the next one eventually going thru all 5 and the front panel says "no discs". I've cleaned all cd's, the laser light, cleaned inside all over to no avail. Please help. Thanks, Bill
  • jacque1974 Jan 14, 2009
    I have the same problem with an Acoustix 5-disc changer. On mine, it's as if the "forward" button, or whatever it's called, is stuck down and so the CD changer just keeps moving to the next CD. Other than that, everything works fine.
  • 26 Answers
The laser or spin motor could be faulty.
Take it to a service centre for professional help.
Posted on Dec 17, 2007
My Sony cd x355 will not load or eject cd,.carousel works fine I can hear motor trying to load for playing.
It may be that the loading belt is bad. Take the cover off and look in the back to see if the belt came off of the pulleys. If so, I would replace both the loading belt and carousel belt as the get dry and stretched out with age.
Sep 24, 2016 | Sony Audio Players & Recorders
Have Sony cdp-c535 cd player. The door won't stay in. Keeps cycling in and out.
I had the same problem with our 5-CD Sony carousel player CDP-C535 (manufactured Nov 1993). I removed the top metal cover, and loaded five audio CDs into the carousel. After I closed the table, I pressed the carousel tight so that it stayed close, and hit the play button. The CD player tried to push the carousel out with quite a force. I needed to warp me fingers around the front panel to keep the carousel closed. After a few cycles of forcing the carousel to remain close, and caused two separate strong "clucks" from the gear area, the CD carousel became operational again. The diagnosis of gear problem seems right.
Nov 28, 2009 | Sony Audio Players & Recorders
In/out dial on bottom of Sony CDP-C305 ... what does it do?
It is Transit Key to protect optical lens mechanism from shocks while transportation unit. remove it before playing unit.
Aug 06, 2009 | Sony CDP-C305 5-Disc CD Changer
Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Dec 27, 2008 | Sony CDP-CX53 51-Disc CD Changer
Please update this with the make and model so I can assist.
May 23, 2008 | Sony Audio Players & Recorders
DVP-NC85H - - Shuffle play among several CDs
You should refer to your Product's Operation Manual for help on this. Also, you may goto for more info.
Apr 29, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Dec 24, 2007 | Marantz CC-4300 5-Disc CD Changer
The Machine only plays when it wants to
TRY CLEANING THE LENS WITH A CD CLEANER OR do it manully with a bit of Vodka and a cotton bud carefully clean the lens in a circle motion then carefully dry the lens with the other end of the cotton bud put it all back together and see if that works
Jun 10, 2007 | Sony CDP-C305 5-Disc CD Changer
Sony CDP-CE375 5-Disc CD Changer Logo
289 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
