Question about Cfm 802 Ecofan Table
Same problem here
I have done the testing and just need to replace the thermoelectirc module.... but Caframo won't sell me one. Anyone know where I can et one that works for the same specs?
  • mmh40c Mar 28, 2014
    Caframo won't sell replacement TEG modules but you can get them from Thermal Enterprises direct or on eBay. They also offer a repair guide.
  • 39 Answers
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Posted on Nov 01, 2009
    Problem Solver:
  • 7 Answers
You can find replacement thermoelectric modules on eBay from Thermal Enterprises.
Posted on Mar 16, 2010
1988 pont 6000 quit and would't restart. Generates 42 code. I have shop manual. Flow chart led to ign. module or ecm. I replaced both. The car idled for 20 min. and quit.
I don't know liter size of engine? I don't know exactly what testing you have done? I need more info?
You have dis ignition? Engine cranking, do you have spark at the plugs, proper fuel pressure and fuel injector pulse?
The purple wire with white tracer from ignition module to computer has a dc pulse with engine cranking? With bypass ignition, engine cranking, it's the ignition module that controls spark, during cranking rpms. Did you check voltage and ground for ignition module. With dis ignition, there is a crank sensor? I'm not saying replace anything. I would have replaced the --spark plugs and plug wires, Possibly the ignition coils.
I just don't know exactly what testing you have done?
If you have already done everything I suggested, then, pardon my post. Just trying to help.
Aug 25, 2017 | Cars & Trucks
I have to replace the transaxle control module but don`t know where it is?
So you need a repair shop or dealer
When one doesn't know where something
is on a vehicle,they also have no vehicle experience
or any idea what their getting into
What testing was done?
How was it done?
Test results?
Vehicle problems?
Codes?
Does the new module have to be refashed?
You can not do that !!
Sort of a silly question isn't it !
Jul 15, 2014 | 2002 Chrysler PT Cruiser
Ecofan not working
The problem is most likely a bad TEG module or possibly a bad fan motor. The most common problem is a failed TEG module. Caframo will not sell replacement TEG modules as they require you to return the fan to them for rebuild but the repair is quite easy. You can find the exact replacement on eBay or directly through Thermal Enterprises. They even have a troubleshooting and repair guide for the fan.
Feb 24, 2014 | Cfm 802 Ecofan Table
2003 Ford Mustang won't shift out of park
Could be the brake switch, or the shift lock solenoid.
Both components would need to be tested. And you may be able to shift out of park if you try before you turn the key switch to the on position.
May 07, 2013 | 2003 Ford Mustang
I have a compaq 6820,s and it won't power up, i get nothing, no screen, sound power, nothing at all. I change the power cord and nothing happen. So could anyone out there help me please?
Try reseating the RAM modules, If this does not work then the RAM maybe faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. If the RAM is faulty them it needs to be replaced.
Feb 24, 2012 | Compaq Presario Computers & Internet
Why is my abs ans ets light on What does it mean
The most probable cause for the ETS (Electronic Traction Control System) light is the ABS light. When there is a problem in the ABS, ETS is disabled.
The ETS uses ABS data to help control the ETS system. You will need to have the ABS computer scanned for codes.
This light usually comes on if you have a failed wheel speed sensor but these vehicles are common for the ABS module to fail causing the same problem. You can back probe the wires comming out of each wheel speed sensor with the wheel lifted in the air and check for ac voltage as you spin the wheel.
What ever sensor does not put out voltage needs to be replaced if they all seeem to work it is likely the ABS module. But before you replace any parts you would want to have the ABS module checked for codes at one of your local shops that has a high end scan tool that can access those codes.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Oct 27, 2011 | 1996 Buick Skylark
Engine will cut out then later start again my 1999 accent cuts out and then starts again after a while. No sparks to the plugs.. Very annoying and no mechanic has yet found problem.
What have any mechanics done?
Do you have an aftermarket alarm? If so, does it disable the ignition? I have seen many, Many, aftermarket alarms go bad and give an intermitent problem.
Has anyone replaced or tested an ignition module? Auto zones can test modules for free.
Sep 28, 2011 | 1999 Hyundai Accent
Do you know if they sell a replacement for the front louvered grill in the lazer 73? Mine is damaged and I removed it from the frame and need a new one.
Parts are available. Contact Valley Power Equipment, Customer Service Dept 1-877-360-3507
Monday - Friday 8am - 5pm ET, Saturday 8am - 1pm ET .
Hope this helped you.
Jul 01, 2011 | Rinnai Toyostove Direct Vent Heater:...
Truck wont crank. we have put new distributor cap, rotor button, coil pack, plugs, wires, and fuel pump. we also checked our firing order.
you said you repl dist cap that means you don't have a crank sensor you have electronic ing module. remove your elec ing module have it tested most auto parts stores could test your module, or check your coil at the neg terminal. should have power. if not you lost your primary volt from your batt.your secondary power is coming from your electronic ing module from the module to the pos terminal on the coil, when the eng cranks,from the coil to the dist cap , from the dist cap center to the rotor then out to the plugs,this all happen pervided the timing belt or timing chain is ok. the cumbustion chainber needs 3 things , thats fuel, air, and spark.
Apr 17, 2011 | 1996 Chevrolet K1500
Cfm 802 Ecofan Table Logo
1,046 people viewed this question
Top Cfm Dryers Experts
Are you a Cfm Dryer Expert? Answer questions, earn points and help others
