Home | Zenith | B25A02Z TV | Moved tv from one roo...
Zenith B25A02Z TV
Problem for Zenith B25A02Z TV
Moved tv from one room to another
By aldridge1200 on Sep 23, 2009
since the move tv has not returned to color quality...no reset button visable. unable to correct color with remote via menu.
please advise.
Solution #1
posted on Sep 23, 2009
Not Rated)
eyecue
Rank: Guru
Rating: 86%, 106 votes
The first thing that I would want to know is what is in that room that could be sending out a big magnetic field. If there is nothing in the room then it is a possible antenna problem and if that is not the case then it is a coincidence that it happened and depending on the age of the set, you might want to see about getting a new one. You can take another set in the room and see if the problem persists to rule out interference.
Was this helpful?
Yes
No
Popular Solutions for Zenith B25A02Z TV
Questions and Unsolved Problems for Zenith B25A02Z TV
Do you recommend Zenith B25A02Z TV?
Answer
Answer
My 25in tv will turn on then will turn itself off after a second or two what could be the problem
Answer
double color red an green 3d light
Answer
I have purchased a new logic 19" flat screen TV. The in built DVD player will not run dvd's. It... (More)
Answer
I have a Zenith 32" TV console and power will not come on by Remote or manual switch. It was... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zenith B25A02Z TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
