Question about Engel Freezer 22 Qt. Fridge/Freezer
My 40 l does not wan to keep stuff cold teh motor kicks in only mometarily, can it be in need of a gas refill and does it ide normal aircon gas? It can get cold by itself but if you stick it with drinks and meet it seems to strugle
  • 909 Answers
If The motor is switching on for short periods, you either have a faulty compressor or a blockage. My money is on a blockage. Once cover is removed to allow you to see the compressor, look for a small fat copper tube that has a small 1/4 inch copper pipe on one side and a thin capillary tube connected on the other side DRIER). Flex this very thin pipe connected to the small fat tube(DRIER) untill it breaks.Gas will come out. Wait untill all gas is out then reswitch on and see if compressor still continues to switch off on short intervals. If it can run for at least 1 min without switching off, then get a Refr.Tech to come and replace drier and regas unit.
Posted on Sep 23, 2009
I have a gram freezer, I cleaned motor on condenser fan, and now it works in the laid down position but not upright?
you should never lay freezers of fridges down as it puts the refrigerant gas in the wrong place. The compressor is a pump, and it pressurises the returning gas in the condenser and turns it into a liquid, this is the 'high pressure side'. The liquid is pumped to the evaporator inside the unit, where there is spare air volume, and the liquid turns into a gas and goes very cold. This is the low pressure side. Your refrigerant liquid is in both places.
Turn it off and leave it upright for 24 hours to settle. If that doesn't fix it, you will need an engineer to empty the gas by sucking it out and then refilling it with new gas.
Dec 17, 2015 | Freezers
Freezer is too warm. We have cleaned all vents but is still in the 40s
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
Regards.
Sep 15, 2011 | Maytag Freezers
It is running but is not freezing the food
Regards.
Sep 15, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
The freezer is not working... It has been slowly warming up for a few weeks. What could be wrong? Also, does this mean that the fridgerator is next to go? We have a GE Model # GSH25KGPA WW
Good luck.
Sep 14, 2011 | Freezers
My freezer is no longer freezing
Regards.
Sep 14, 2011 | Hotpoint Freezers
I own a frigidaire model # CF-5D-L*2 manufactured in Feb. 1987 and it stopped cooling off. I've looked at the underside of it and don't see anything off the bat that would be wrong with it. Can you...
Good luck.
Sep 13, 2011 | Frigidaire Freezers
Freezer not getting cold enough
dear sir/madam
make sure first your freezer,s condenser fan motor is working if it,s working and its not getting good cool then it can be low gas problem so please contact to your maintenance personnel for find out the leakage and make it brazing and after refill refrigerant gas.
hope answer the question
thank you
please vote!
Aug 09, 2010 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Refrigerator still works fine but freezer while cold is not cold enough to freeze
dear sir,
please make sure first your freerzer,s condesore is clean and fan motor and compressor is running. if its alredy clean and working then try to check amount of refrigarant in your freezer. i think its need to refill freon gas.
thank you
please vote!
Jul 03, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer not cold enough
the dryer is already sock ,, you need to change it and refill the gas
Jan 24, 2010 | Freezers
GE side by side freezer/refrig-model # pssz6mcpa-motor in freezer not running, icemaker not working and freezer not cold enough
Sometimes they stick and need a shot of WD 40 and then workit back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 04, 2010 | Freezers
Engel Freezer 22 Qt. Fridge/Freezer Logo
184 people viewed this question
Top Engel Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
John Tripp
John Tripp
Are you an Engel Freezer Expert? Answer questions, earn points and help others
