Question about HP iPAQ HX2700 Pocket PC
On IPAQ hx2700, how do I do a hard reset? I want
On IPAQ hx2700, how do I do a hard reset? I want to erase all information on this and sync to a new computer.
  • HP Master
  • 4,338 Answers
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Posted on Sep 23, 2009
Testimonial: "Thank you so much! I really appreciate your help as I don't have the manual for this particular IPAQ model. "
  • 36 Answers
Easy way - search the internet for hardreset.cab.
Download and install the program. When you run it, Ipaq will hard reset.
Posted on Jan 16, 2010
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
HP Pocket 2003. Need to restore information but not recognising profile. Where do I find the files on PC to copy mobile devise. Using XP student edition
Syncronation profile? you should make a new active sync profile.
or do you mean something else? please be more spesific.
if your device was hard reset and you need to restore something.
tell me what exactly.
Mar 28, 2008 | Computers & Internet
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
loaded are stored.
HP iPAQ hx2410 Hard reset
functionality.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
HP Ipaq h1940 won't sync with Vista
Hi. While holding power button, and pressing reset will do a hard reset to your PDA (reset the device to its factory default settings). So if your PDA is working well, don't do it. As for the syncronization with your Vista PC; Winodws XP uses the ActiveSync software for syncronization, and for Windows Vista, Microsoft developed a brand new syncronization software called "Windows Mobile Device Center". It can be downloaded here: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx). When you download/install this software to your PC, you should be able to connect your PDA to your PC without any problem, and definitely without changing any OS in your PDA or PC. Hope this helps.
Jun 01, 2009 | HP iPAQ H1940 Pocket PC
Ipaq hx2700 not playing fair
It may not be an answer but make sure you are using the proper Link G-link and N-link. Also if its a Dlink card make sure when you are installing the drivers from the disk that you DO NOT have the hardware connected, You insert the card after you run the drivers installation disk. Hope this is helpful.
Good luck =)
May 29, 2009 | Linksys Wireless-N WRT150N Router
IPAQ 4700 hard resetting on its own.
I also own an ipaq 4700 and experienced the same problem. Even after reloading the OS I continued to have this problem. I did buy it refurbished but I fear this may be a common hardware problem. From my research it would appear the battery is the most likely culprit, I have not tried replacing mine but it may be worth a shot, if nothing else you have an extra battery which means less time at the charger :D
Apr 16, 2009 | HP iPAQ HX4700 Pocket PC
Unit loses battery power
Most likely, the battery is defective. I have just had a similar problem and purchased a new battery. The PDA is fine now.
Dec 18, 2007 | HP iPAQ HX2700 Pocket PC
Full Reset
You need to press buttons 1 + 4 + Reset until the screen turn off, after that wait for 60 seconds and press the reset button again. remember that hard reset erase everything from your ipaq like personal information, programs that you installed, etc.
Xracer
Dec 05, 2007 | Compaq iPAQ H3955 Pocket PC
IPAQ H5500 USB CONNECTION TO PC NOT WORKING
open active sync on ipaq and connect the cable with pc and ipaq. if not recognised perform a soft reset on ipaq. also check in  active  sync on pc >file> connection settings> allow usb connections is checked
Jul 20, 2007 | HP iPAQ H5555 Pocket PC
Media player 9 on ipaq 2215
A hard reset will get it back for you, but you will lose your data. So either backup first, then restore it. Or sync to PC and back if it's just OUTLOOK data.
Sep 11, 2005 | HP iPAQ H2215 Pocket PC
HP iPAQ HX2700 Pocket PC Logo
1,394 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
