Question about Bass Pro Boating
What role does the trim tab on an outboard play as far as handling and hard steering, and how do you adjust it?
  • 677 Answers
If you are talking about the small tab under the cav. plate.Its job is to counteract the effect that the prop has on steering.Because the props. spin in one direction,they create a sideways pull on the motor due to the prop biting into the water and trying to pull all with it.2 motors on the 1 boat often have a different gearbox fitted,and one will spin in the opposite direction and this counteracts torque steer.To adjust yours,work out where you drive the boat most.Speed etc.Higher speeds have more effect.If it pulls right,adjust it left.One bit at a time.I think yours will have an allen key or hex screw above the tab.Loosen it,move the tab.Takes only minutes.I hope this helps
Posted on Sep 24, 2009
What does a trim tab do on an outboard motor
Reduces the force of the outboard motor pushing the stern down and the bow upwards which increases the available thrust to push you forwards
Feb 19, 2017 | Boating
The motor is on a 1995 Basscat Pantera 2 and the motor has no steering trim tab. Guy said it came that way new. Would this be correct.
Best to reply as comment on your original post so that Guy or whoever will get the feedback.
I don't know what motor you are playing with, but the fin style zinc or aluminum anode that attaches to many engines (just below the anti-cavitation plate) can be set at an angle to function as a steering trim tab.
Cheerfuls
Oct 07, 2015 | Boating
How do you adjust steering handle on older 6hp chrysler outboard
I think I would spray it down good with wd40 and wait a few days .
Sep 21, 2014 | Boating
What trim tabs on the radio control left , right, up and down?
on your controller you will have little handles that move all around these are your controllers, next to them are little switches that slide up and down or left and right. these are your trim tabs, with a little adjustment to these switches the elevator and rudder, and some cases airelons can be brought to a neutral position which makes flying much easier.
Jun 13, 2014 | Heli-Max 1SQ Quadcopter RTF SLT 2.4GHz
Outboard troubleshooting
sounds like a sticky relay . non repairable just replace with new relay.
Mar 15, 2014 | Boating
Boat steering
Pretend your lower unit is a little boat and you want it to go to the left. Which way would you point the motor, --do that with the trim tab.
Jul 17, 2012 | Boating
1989 galaxie boat. inboard/outboard 4.3l stiff steering
The first thing I would do is disconnect the steering at the transom. You want to find out if the problem is in the helm(steering wheel) or in the inboard/outboard pivots.
When you turn the wheel after the disconnect, it should not be hard. There is a set screw in the steering assembly either above or below the dash. There should be enough tension so the boat does not wander but not enough to be terrible to steer.
Next go to the outdrive. Without the steering connected, the outdrive should move with minimum resisitance in either direction. There are pivot points on top and bottom that should have marine grease at the start of each season.
You have a 21 year old boat. The driveshaft in the Inboard/Outboard should be greased every 2 to 3 seasons and the watertight bellows can be inspected at that time.
Now if the steering is even worse under power, you need to adjust the fin that drops down behind the prop. This part controls Torque steer so the outdrive is not trying to turn on you and wants to stay straight. If you do not have a problem leave it alone.
You can get an estimate for the driveshaft service and greasing U-joints and inspecting the bellows. They should grease the pivot points then too. I am told its about a 2 hour job. In my area its 60-70 an hour.
Apr 12, 2010 | Boating
How do you take off inner driver side door panel with out breaking the the snaps and panel itself
Sometines the panel retainers do break, they are available at most parts stores, you should use a special tool to remove them (pic below)
Front Door Panel: Service and Repair
Trim Panel Replacement - Side Front Door
REMOVAL PROCEDURE
TOOLS REQUIRED
J 38778 Door Trim Pad Clip Remover
1. Remove the inside handle bezel (2).
2. Remove the fastener (1).
3. Lift the flap (1) in pull handle opening.
4. Remove the two fasteners (2).
5. Remove the two fasteners (1) from bottom of trim panel.
6. Using the J 38778, release the eight retainers.
7. Lift upward and outward on the door trim panel.
8. Disconnect the door latch cable from the inside door handle.
8.1. Pry the tab on the cable outboard while pulling back on the cable.
8.2. Unhook the collar portion of the clip from the cable attachment.
8.3. Push upward on the bottom of the cable attachment to disengage the cable from the handle clip.
9. Disconnect the electrical connectors.
10. Remove the door trim panel.
INSTALLATION PROCEDURE
1. Partially install the door trim panel.
2. Connect the electrical connectors.
3. Connect the door latch cable to the inside door handle.
4. Raise the trim panel over the lock knob and align the fasteners (1) in the holes in the door assembly.
5. Secure the trim panel to the door assembly by applying sufficient pressure on the trim panel.
NOTE: Refer to Fastener Notice in Service Precautions.
6. Install the two fasteners (2) under the inside pull handle opening.
Tighten
Tighten the fasteners to 2 N.m (18 lb in).
7. Install the inside trim panel cover fastener (1).
Tighten
Tighten the fastener to 2 N.m (18 lb in).
8. Install the trim bezel (2).
9. Install the two fasteners at the lower portion of the trim panel.
Tighten
Tighten the two lower fasteners to 0.5 N.m (4 lb in).
Oct 30, 2009 | 2000 Cadillac Seville
1989 Javelin FS396 lisp to the left constanly
Does the steering pull to one side while coming up to speed.
Have you adjusted the trim tabs on the motor?
they help to counteract the prop torque.
the motor will naturally have a torque to one side
because of the prop rotation.
Dec 21, 2008 | Light Outboard Motor Boat Bass Fishing...
The window fell off it rollers
  1. Remove all door inside handles.
  2. Remove the door inside locking rod knob.
  3. On styles with door pull handles, remove the screws inserted through the handle into the door panel.
  4. On styles with remote control mirror assemblies, remove the remote mirror escutcheon and disengage the end of the mirror control cable from the escutcheon.
  5. On styles equipped with switch cover plate in the door armrest, remove the screws securing the cover plate, then disconnect the switches and cigar lighter, if so equipped, from the harness connectors.
  6. Remove the remote control cover plates and remove the exposed screws securing the cover plate to the door inner panel.
  7. On styles with integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. On some styles it may be necessary to remove the screws behind the armrest deflector or courtesy lamp remote control cover plate. On styles with armrest applied after the door trim installation, remove the armrest to door inner panel attaching screws.
  8. On styles with with two piece trim panels, disengage the retainer clips at the front and rear of the upper trim panel. Remove the upper trim panel by lifting upward and sliding slightly rearward to disengage the the front door inner panel at the beltline.
  9. On styles with electric switches located in the door trim panel, disconnect the wire harness at the switch assembly.
  10. To remove the lower trim panel, remove the attaching screws along the upper edge of the lower trim panel. Then starting at a lower corner, insert a pry type tool between the door inner panel and the trim panel and disengage the retaining clips down both sides and across the bottom. On styles with courtesy lamps or reading lamps located in the trim panel, disconnect the wire harness at the lamp assembly.
  11. On styles with one piece trim panels, remove all the clips around the perimeter of the trim panel. Push the trim panel downward and outboard to disengage it from the door inner panel at the beltline. Disconnect any courtesy lamp wire harnesses, if so equipped and remove the trim panel from the door.
  12. Installation is the reverse of removal. On styles with adjustable trim supports at the beltline, the door trim panel can be adjusted in or out so as not to restrict door window operation.
Oct 14, 2008 | 1988 Cadillac Sedan DeVille
Boating Logo
178 people viewed this question
Top Bass Pro Boating Experts
ray gallant
obsteiner
Gordon Richard...
Are you a Bass Pro Boating Expert? Answer questions, earn points and help others
