Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
THE COLLERS RED AND GREEN ARE SHADOES EVERING ON
THE COLLHIERS RED AND GREEN ARE SHADOES EVERING ON TV
  • 10,594 Answers
It is failure of convergence out chips in your TV , requires replacement of these ICs to correct that error.
If it is Philips 60PP9202 model then click HERE for more details about how to get it fix and where to buy parts.
If model and brand is different, let me know to guide you more.
Thanks.
Posted on Sep 23, 2009
Had power outage kill power, while tv was on evering thing went off everything came back on except tv
Check its main power regulator board. There is a protection fuse on it. Check it.
Nov 29, 2012 | Toshiba 30HFX85 TV
Emerson problems
Look for any jammed buttons on remote or on TV control panel. Try changing the input device to something you are sure, works. Try changing the settings to factory default and see.
Jul 28, 2012 | Emerson 32in Class LED-LCD 720p 60Hz LED...
I have a dell demension 2400 lghts one the back r different collers lights a&b r yellow lights c&d r green
You have a memory failure. If you have more than one memory stick(ram). You can try pulling one out and trying the other in the open slots and restarting each time, if it starts normally that stick is good. It could possibly be a bad connection so make sure they are in all the way.
Apr 01, 2011 | Computers & Internet
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Sep 04, 2010 | Sony DVP-NS400D DVD Player
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
When using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Feb 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Hook up of dvd to tv
hey I think you need to use component cables blue green red from the player to the tv, make sure the blue green red ports are also on the tv, note: red yellow white composite cable will not interchange with blue green red component cable or connection.
simplify- blue green red= component
red white yellow=composite
*wires must match colors on both tv and player inputs.
then set your input on your tv to where you conected the cable.
Jun 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
48in projection tv jvc
you need to replace both convergence ICs STK392-110 and you also need the JVC convergence resistor Kit # 1 . You can get them at the following link with free detailed instalation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Aug 07, 2008 | JVC AV-48WP74 48" Rear Projection...
wow, i have the same problem with mine. did u get a answer to this?
Jun 23, 2008 | JVC AV-48WP74 48" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
