Question about Microsoft Xbox 360 Console
My xbox 360 has sound but no picture. DVD player works on sam AV input. Also tried the HDMI cord, same result. What now
    Novelist:
  • 168 Answers
This i have seen before and it tells me the machines is displaying the signs of lead free solder failure (85%sure). you could strip the machine down and replacing the x-clamps at the same time do the heatgun fix if you dont have access to an IR oven.
To me it will just get worse and will definately need the x-clamps replacing AND the solder re-seating.
hope that helps in some way
www.xboxrepairkit.co.uk
Posted on Sep 26, 2009
My WD-60735 doesn't recognize my xbox 360 in HDMI or AV. DVD player works fine in AV, Xbox works fine in HDMI and AV on another tv. Just goes to blue screen on this tv.
have you set your settings for 720p on your xbox then turn the tv on to the right input then turn the xbox on? i had that issue with a previous tv? does the lights on your xbox just spin around?
May 14, 2011 | Mitsubishi WD-60735 Projection Television
I have just bought an xbox 360 conected it to my tv allcables connected picture great but no sound
Hi Douglas
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
Mar 05, 2011 | Microsoft Xbox 360 Console
I'm trying to set up my Onkyo HT-r380 receiver (which came in the HT-S330 home theater system). I can get AM and FM radio to play on all the speakers. I can not get sound from my XBOX 360. The 360 is...
I looked at the manual and they provided the following settings.
To listen to audio received by the HDMI IN jacks through your TV's speakers:
  • Set the "TV Control" setting to "On" (? 37) for an p-compatible TV.
  • Set the "Audio TV OUT" setting to "On" (? 36) when the TV is not compatible with p or the "TV Control" setting to "Off".
  • Set your Blu-ray Disc/DVD player's HDMI audio output setting to PCM.
  • To listen to TV audio through the AV receiver, see "Connecting External Components" (? 17).
Jul 19, 2017 | Audio Players & Recorders
No picture, No sound only snowflakes!!! Can you help?
Make sure that your tv is on the av setting(or hdmi what ever the input is) also make sure the input is working by testing it with another device (dvd player,etc) If you are getting snowy picture you could be on the analogue tv channel. Good luck.
Nov 17, 2009 | Microsoft Xbox 360 Console
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox 360
If it has a hdmi cable and you or a friend has a tv compatible try and get a picture from their.
It sound that you might have a faulty cord for the video, or possibly the video drive has gone out on the 360, witch is a reported problem on many consoles.
Try to use b/g/r or the hdmi.
Is your switch on the correct location?
Av or High deff.
Good luck
Sep 11, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Color problems with 360
It sounds to me like a problem within the 360s hardware itself. You could try sending it back to microsoft or like you said, going out and getting a new one.
Sep 03, 2007 | Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
