Question about Canon ES8400V Camcorder
No video or audio in playback mode
Camcorder will not playback audio or video all of a sudden in LCD screen or viewfinder. Had no problem prior to today.
  • snickeldorf
    snickeldorf Jan 06, 2008
    i cant playback anything, i have never had this problem
  • Anonymous Apr 29, 2008
    i can't see nothing on playback after recording. nothing shows on the screen.
I Had a similar problem with my 8600. Most likely the camera
is also no longer recording. There were two problems I found,
either one could have caused the problem. 1) the 8mm tape was not
actually moving through the record/play head. With modern cameras. there are no indications that the tape is actually moving.
2) the record/play head is dirty. What I did was remove the
side plate that covers the tape cassette to allow me to verify that
the tape was moving properly. After that, I removed the tape, removed the battery, and used isopropyl alcohol and a q tip
to clean the head. I imagine there are cleaning tapes that one
can buy to do this as well. though I doubt they work as well as
a q tip. THere are two screws that hold the cover on.
Posted on Feb 21, 2008
When I turn on the camera I get a white screen on hte monitor and nothing in the viewfinder. This occurs in the still, record and playback modes.
It sounds video processor is not getting voltage from sub power supply section on main board of camcorder that is why you do not get any video output in lcd or viewfinder in any mode.
I'm Sony camcorder tech and can help you if you are handy with electronics stuff repair and can take apart camcorder easily with proper tools.
In my opinion, there would be fuse blow out that provides volts to video signal section. Let me know exact model number of camcorder to proceed and if you feel uncomfortable working on camcorder then local camera repair shop is an option to get it fixed.
Hope these info will help you.
Nov 07, 2010 | Sony DCR-DVD301 DVD Camcorder
I can turn my camera on, but there is no screen or sight for recording or play edit.
normally, if you can turn the camera on everything should work including the lcd. if its just an issue with the imaging sensor, you wont see anything on the viewfinder (for the viewfinder to work you need to close the lcd screen) but should at least see the indicators, same in the lcd screen and view your videos in playback mode. if its an lcd screen issue, there would be nothing coming up in any mode the camera is set to. you can try to reset cam back to default settings (press reset while cam is on, its located on the side where you have the handstrap, just below the speaker), or do power reset (remove the batt and ac adapter for at least a minute). if still the same, your unit may require service. thanks. hope this helps.
Jul 21, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony CCD-TRV65. Blue screen during playback
Just bought the exact one from a yard sale for 20 bucks. Had the very same problem with the blue screen on playback. What i did is replace the battery in the small bay when you open the viewfinder. Try playing your tape again and it will work!
Feb 01, 2009 | Sony Handycam CCD-TRV65 Camcorder
Image distorted in both modes canon zr85 camcorder
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced to back in business.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Good luck.
Dec 25, 2008 | Canon ZR85 Mini DV Digital Camcorder
Nothing in viewfinder or on screen
Same thing happened to me. Seems to be 'common' although Sony says they have no recall on the CCD. Look around the forum and you will find others with the same problem.
May 24, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
model # is required for me to help you.
Sep 09, 2007 | Canon DC10 DVD Camcorder
Camcorder LCD screen only operates up to 30 degrees from camera
open the unit. find the flat flexible connector to the LCD and then look at each end to verify if fully inserted into its mating connector.
May 30, 2007 | Panasonic NV-GS15 Mini DV Digital...
No picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
May 19, 2007 | Canon GL2 Mini DV Digital Camcorder
Canon ES8400V Camcorder Logo
271 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
