Question about Zenith L15V36 15.1 in. HDTV-Ready LCD Television
Where does the power cord go?? i moved and I am so confused where the plug goes into the tv!
    President:
  • Zenith Master
  • 1,779 Answers
From the rear of the set, on the very right hand side of the input panel, you will see a 3.5mm jack that says DC 12 v input. That is where the small power cord gets plugged into.
Posted on Sep 23, 2009
Hello,my Sony Bravia HD TV (LED & LCD) we suspect that it was struck by lightning,but my other appliances connected on the same power cord as my tv are working fine,so i'm confused..
The power surge from lightening can come in thru the antenna or cable box. Also just the proximity of lightening can damage one item and not another. An ic chip can be destroyed from the charge in the air.Likely took out power and main brd both.
Mar 19, 2014 | Sony "KLV-40BX400 40"" 1080p Multi-System...
VIZIO power failed, PC blacked out and will not start. Power cord LED goes off immediately when plugging into PC.
whatever happened you need to fix the TV first and maybe not try to hook the laptop back?
Nov 05, 2012 | Televison & Video
Do you have a picture of it? Be sure to look at the two five amp pico fuses on the Power Supply board (orange and look like resistors) which should be on far left side as you look from the back where the...
see attached photo of board (power cord goes to it and it is mounted on its side) the fuses are middle to right edge behind the plugs on the rear edge of the board.
Orange, 2 side by side and marked 5a each on the top of the board (5 amp)
Sep 26, 2011 | Sony KP-51WS500 51" Rear Projection...
I just got a Vizio 320VL two weeks ago and I was trying to program my oceanic cable box then I turned the TV back on and it goes on and flashes the VIZIO on screen then it goes out. Can you tell me how to...
I purchased this tv yesterday and have noticed that the power cord is loose where it plugs into the tv. If I move the tv slightly I lose power.Try checking the plug.
Nov 27, 2010 | Vizio L32 32 in. LCD HDTV
I have a CLT2054 and lost the power cord. I bought a new power cord but when I plug it in the light on cord goes out and TV wont come on. If I un plug cord light comes back on
You have short circuits inside the TV, the AC goes into shutdown when it senses too much current being draw. Post some pictures inside the TV if you can, wee need to look for short circuits, another thing, you bought new AC adapter with the same voltage and current rating, right?
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 29, 2010 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Panasonic CT36SC13 remote or front power button will not turn off
Solution1:
a)Inside the tv there are microswitch CH+- Vol +- power, menu: when the ones are faulty," tv tends to behave at its own", change them, of course before to buy'em, unsolder th'em and try with the remote, tv has to work with out'em.
Apr 08, 2009 | Televison & Video
Power cord
you would need a qualified tv personal to re- insert the power chord
Jan 20, 2009 | RCA 27V530T 27" TV
Screen goes black when a/v cord connected
I had a bad cable on mine. Once you plug the cord in the camera controls will appear on the screen. If you get a hold of Sony they can get you a new one.
You might be able to find a new one at a computer store depending on what connection goes to the back of you camera to get it to work (like a mini jack).
Jun 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Need new power cord
Recommend against soldering the damaged ends together - it's ugly, will never be especially safe, and risks being unreliable too. Have a look at the TV end of the cable. Does it go straight into the TV, or is there a plug that goes into the TV. If there's a plug, just pull it out, take it along to shop that sells TVs and they'll sell you a new one off the shelf. If the cable goes straight into the TV, the solution is just a tiny bit more involved. First, look at the mains plug to check whether it is moulded on, or rewirable. If moulded on, you will need both a new plug, and some flex. If rewireable, you'll only need the flex. Either way, take the cut-off end to Home Depot or somewhere similar and buy something the same shape and size (thickness of the wires is the important thing here). To fit, carefully take the back off the TV and look at how the existing cord was connected and secured before removing it and putting the new one on in exactly the same way. Don't forget to push the wire through the hole in the case (if there is one) before connecting it up. Once the flex is fitted to the TV, fit the plug to the other end. Safety/reliability tip 1 - while the back is off, try not to touch any electrical or electronic components inside the TV other than the power terminals you're supposed to be working on. Saety tip 2 - when renewing a power cord, wire the new cord to the appliance before fitting the plug to the other end of the cord - amazing how many people have helpfully been plugged into the mains in the middle of a job. A.
May 01, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Zenith L15V36 15.1 in. HDTV-Ready LCD Television Logo
65 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
