Question about Northstar 6000I GPS Receiver
Northstar 600i locks up and at times you can't switch screens, turn it off or even turn it on. You have to wait and come back later to turn it off or on???
  • 43 Answers
If you can delate all you log, waypoint routs or make a masterreset.
With a masterreset you will lose all data below
Posted on Oct 15, 2009
My machine bizub 600i show on screen c3503 how to remove this by which i cando
Power off the machine, using the main power switch located inside the machine. Then ensure the sub power switch is on that's the one on the control panel. Now depress the Utility/Counter button and turn on main power must keep the button depressed. once you see trouble reset touch it get a OK. Power off then wait ten seconds and power back on. If the code comes back do not reset again the machine can catch on fire and that will ruin a perfectly good day. get a technician to look at it The Fuser is not something to mess around with.
Jun 02, 2015 | Konica Minolta Developer 02xk Dv710 for...
Lock light turns on then blinks and wont start
Possible that the lock switch contact has some issues, try a cleaning spray on the switch and open and close the door several times with the spray. This might clear the switch contacts.
Also make sure that the contacts to the connectors from the control panel are in order, remove and tighten or repeat few times.
Otherwise the control panel can be a suspect.
Jul 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
Keyless entry
That has to be done with the special scanner called a Tech2 at the dealer, the scanner allows for an interface to be established with the security module for reprogramming, so sorry you can't do this at home.
Feb 09, 2012 | 2002 Chevrolet Tahoe
1996 Cadillac Eldorado northstar starter prublomes
Clicking sound ? loose connection , bad battery or battery cables . Do a voltage drop test on the starter circuit . Do you have an know how to use a DVOM - digital volt ohm meter ?
How to voltage drop test starter motor circuit
Starter Voltage Drop
Jul 18, 2017 | Cars & Trucks
I am having a problem with my printer. When I turn it on the copy light is on and the feed switch light and the alarm light and it says in the screen release the scanner lock switch and turn the power off...
Issue: ERROR LCD: Release the scanner lock switch and turn the power off and back on.
Solution: Unlock the scanner lock switch
The scanner must be unlocked before turning the unit on.
Turn off the power.
Lift the document cover.
The scanner lock switch is on the left hand side of the underside of the document cover.
Slide the scanner lock switch to the release mark (an open padlock icon).
Lock the switch before transporting.
Close the document cover.
Turn the machine on.
If machine still is not working repeat the power off / on cycle waiting 5 seconds in between.
Jan 25, 2011 | Canon MP830 All-In-One Printer
When I turn on the tv, Get a blank screen with
Unplug it,replug it back an hour later,the tv should set back to the factory setting.
Mar 22, 2010 | Toshiba 22LV505 22 in. LCD TV
Northstar 951 GPS shows boat moving & @ high speeds (over 100)
RE: Northstar 951 GPS Receiver
Contact & Support @ http://www.northstarnav.com/en/Support/
jack
0501102.jpgPlease Rate This Now or Later!
Feb 22, 2009 | Northstar 951XD GPS Receiver
What does the errror code F90 mean?
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Turns on by itself
format the player it sounds like the settings may be causing this or just a glitch then reload firmware. if not ... well I dont know
Dec 16, 2007 | iRiver H10 MP3 Player
Kenmore gas range trouble
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 20, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Northstar 6000I GPS Receiver Logo
220 people viewed this question
Top Northstar GPS Experts
Jose Ma DM.
Jose Ma DM.
Are you a Northstar GPS Expert? Answer questions, earn points and help others
