Question about Acer Aspire 5315 Notebook
Hi my sisters laptop is a acer 5315 series and as soon as you push the power button the laptop shuts off after 2 seconds
    Problem Solver:
  • 15 Answers
Please give detail of ur problem..
Posted on Feb 06, 2010
Have you had the power adapter checked to see if it putting out the proper voltage required for running the laptop and charging the battery? You might also want to check your power jack to be sure it is not bad or the solder connections to the board are not broken.
Posted on Sep 25, 2009
How can i install my recovery cd on my acer 5315-2492.
The recovery disk consist of 2 DVD, the first is the System Disk (this is first disk to insert), once finished loading, it will ask to insert the second CD (Application and Drivers disk), if in case both are not working, then follow the below mentioned steps:
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also place order for a set of Recovery disk by calling Acer Technical support at 1 800 816 2237
Thanks and regards,
Jitha
Dec 17, 2010 | Acer Aspire 5315 Notebook
The Acer 5315 notebook I have will not power up. It is plugged in and when I press the start button, the power light is on for about 2 seconds and then it shuts down. I removed the battery and it will not...
most probably it is the motherboard. try to turn on the computer using the ac adapter without the battery. if the problem is the same, the motherboard is already defective.
Jun 11, 2010 | Acer Aspire 5315 Notebook
Acer Asipre 5315 laptop Battery A/C supply plugged in, hit power switch and the power light blinks 2 (maybe 1 time)times but the unit does not power on.
remove the battery and power cord then remove the battery on the mother board, hold down the power button for 60 seconds to drain the capacitors, if that doesn't work it's the motherboard that should be replaced.
Feb 19, 2010 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 refuses to boot up
plz try by reinstalling the operating system, if you cant then plz check your hard drive
Jan 13, 2009 | Acer Aspire 5315 Notebook
ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
Dec 20, 2008 | Acer Aspire 5315 Notebook
My Aspire 5315 will not start
I actually contacted Acer by email for this and got a reply in less than a day.
Try the steps below for a power reset, to eliminate a hardware problem with your notebook:
1. Disconnect the AC adapter from the laptop.
2. Remove the battery.
3. Press and hold the power button for about 30 seconds then release it. (You will not see anything happen)
4. Connect the AC Adapter to the laptop. Make sure the AC Adapter is plugged in.
5. Turn the computer on as normal.
6. Once Windows boots, insert the battery.
If the notebook still does not power on, we recommend the notebook be serviced by our authorized repair depot. You can set this up for service yourself by going to www.acerpanam.com; click on the link for Depot Repair. If you are out of warranty, or you would rather do this via phone, please contact Acer Technical Support at 1-800-816-2237, Mon-Fri 7am-9pm CST and Sat-Sun 8am-5pm CST excluding holidays. For out of warranty products please call 1-866-621-2237. Hours of operation are 7am-8pm CST, Mon-Fri, and Sat-Sun 8am-5pm CST excluding holidays.
Dec 17, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
