Question about Epson Stylus C48 InkJet Printer
When I print a ten sheet business cards.The text is moved down on every card.1 cms form top first card, last card 6cms
  • 2 more comments
  • artbydesignz Sep 23, 2009
    All the settings eg. margins are set correctly.But Ihave same issue when using publisher or printshop.
  • artbydesignz Sep 24, 2009
    Yes I did.Thanks
  • fougzki May 11, 2010
    Did you try to print with just a single sheet for every printing job?
  • 95 Answers
It maybe from the settings, do you still have the same issue on printing regular documents. it may also differ with your program
Posted on Sep 23, 2009
Prints on two cards
You can modify the position in the menu.
The start position can be prgrammed in the personal settings.
Moving the paperwon't change anything because the printer will always check the top of feed
Sep 03, 2009 | Datamax I-4208 Thermal Label Printer
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
My business cards will not print from Printmaster Gold to HP 2410 Printer. Everything else prints except business cards. I get a box that indicates the are printer but nothing prints.
your cards are too thick .the printer wont actually move the card down to yhe printing heads. try placing just one sheet into the printer or/and go to setup and see if you can set the printer for thicker paper try user defined setting. no promises.
Apr 19, 2009 | Broderbund PrintMaster Gold 16 for PC
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Problem printing business cards
    I had this problem today and think I've figured it out. Take a sheet of plain paper and two little pieces ot clear 'scotch' tape. Tape the blank sheet behind the business cards at the top/feeder edge and try again. You may need to tweak it a bit more but it stops it from printing so far up.
    Jul 19, 2008 | HP Deskjet 3845 InkJet Printer
    Printer has started to misalign text, moving up past labels
    Verify your paper settings match between the printer and PC. If a roller is dirty the paper might feed late.
    Jun 17, 2008 | HP LaserJet 2420 Printer
    in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
    Mar 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
    Print Garbage
    The reason your pictures come out dark and grey is that you have not set the paper thickness on your printer. On the back you will see a flip switch change this setting then feed your business card sheet in there and see the diffrence. Plus make sure your settings for your printer are set for a thicker paper this will fix your problem. Make sure though when done printing your cards that you set it back to the normal or you will have problems printing regular paper documents.
    Sep 15, 2007 | HP OfficeJet 7310 All-In-One InkJet...
    HP 1310 series
    I have an HP PSC1315 which is virtually the same printer. I actually created my own template where 10 business cards are printed as if it were one sheet of paper(like a poster). Of course you you can't select how many cards print, or which card to start on, but at least I get 10 perfectly centered cards.
    Sep 04, 2007 | HP PSC 2210xi All-In-One InkJet Printer
    Epson Stylus C48 InkJet Printer Logo
    Top Epson Office Equipment & Supplies Experts
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
