Question about Watches
Changing the battery
I have purchased a new battery for my timex watch. The back of the watch does not have screws. It probably is a pop off type. I do have a small flat screwdriver from my sewing machine. Is there a place to pry it off? Please advise. The back says Timex Stainless Steel Back Cr 1216 cell WP 30 M
  • MR David Bush Jun 29, 2013
    mine does come off with 4 screws,but how does the fit in with the 2 clips at ever side,one thin on the left and one a bit bigger on the right,i took the battery out a malayian battery and bought a japanese maxwell battery the same size but it is litium how do they clip in maxwell
You need to pry it open.
I used an X-acto knife
Posted on Jan 08, 2008
How do i change a watch battry
Try ebay for a watch repair kit. I got one for about $10 a year ago. It pops the watch apart without screwdrivers.
Oct 05, 2016 | Timex Watches
Change the battery
there are two types of back /snap on and screw on this link below will help you
http://www.watch-batteries.com/Changing_a_battery.htm
Jan 20, 2013 | Timex T42361 Outdoor Chronograph Alarm...
I have a Timex Ironman 30-Lap Mid watch with a dead battery. I purchased a CR 2016 battery as stated on the back cover of the watch. How do I change the battery?
This one is quite simple. Just remove the watch back with a watch case knife and flick out the old cell then carefully press in the new one (VERY carefully as the movement is made of plastic). fit the back exactly the way it came off (note the direction of the writing).
Sep 19, 2010 | Timex Watches
How do I put the back on a timex watch after I replaced the battery?
Depends on what type of back it is. Is it a pop on? If you cant pop back on, may need to go to a jeweler. They have a watch press that allows you to get the back back on.
Jun 30, 2010 | Timex 27191 Wristwatch
How do I get the old battery out?
Very risky to do by yourself without the proper tools. If you don't want to spend the 6 to 12 dollars to have the battery changed by a professional you will likely need to remove the strap by disconnecting the pins and then screw off, unscrew screws, or pop off the back with a sharp knife. You can now replace the battery and put back together.
Oct 17, 2009 | Timex Marathon Sports 59071 Wrist Watch
Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
hi
please follow the steps to change the battery
  1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
  2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
  3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
  4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
  5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
thank you....
Apr 08, 2009 | Timex T41091 Expedition Watch
How do i change the battery in a timex wr 30 m watch
remove back cover plate- inside you will need a jewlers screw driver- install new batery in reverse. install screw- and snap cover back in place.Make sure battery is new.
Dec 31, 2008 | Timex 27191 Wristwatch
Timex expedition compass battery replacement?
hi
i am not an expert in this particular case but i followed theses below steps . here are they.....
Unscrew the case back with a case back tool (aka Jaxa wrench) which engages
the notches in the case back. I'm assuming the watch has a screw back - if
it has notches it does. Pop out the old battery.
In some watches you have to
unscrew a clip but in most the battery pops right out. Examine movement for
evidence of battery leakage or other damage. Carefully clear away any crud
at the edge of the case - the tiniest metal shaving will short out the coil.
Install new battery of same type. Handle new battery with non-metal tweezers
or rubber gloves, never bare fingers. Inspect case back gasket or preferably
just replace it with new o-ring of same size. Gasket should be lubricated
with silicone grease. Reinstall case back using wrench. If you are
concerned with water resistance the watch needs to be tested in a pressure
test machine. I'm sure the pros have more tips but this should suffice for a
Timex where it would not be a big loss to damage or break the watch.
i hope you can successfully replace the battery
thank you
Sep 06, 2008 | Timex Digital Expedition watch
Have timex watch had battery replaced and watch quit working, she had to use clamp device to instal battery
If you had the battery replaced, I'm guessing that the watch wasn't working when you brought it in for a new battery. It may not have needed a new battery. You might need a new watch. I've never heard of anyone needing a clamp for a Timex digital watch. In my experience, they use phillips screws to hold the back to the case. I have a case press for snap-on backs, but that's still unusual for a Timex unless it has a BIG case. I think your watch was shot before you replaced the battery.
Apr 26, 2008 | Casio Atomic-Solar Watch GW300
I have a Timex Ironman 53151 watch but there is no sound. The light and everything else works except the sound. What is wrong with it?
got a new battery in ironman and the beep will not sound when i press the start and end button on while in stopwatch mode
Apr 19, 2008 | Timex Ironman 53151 Wrist Watch
Watches Logo
920 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
