Question about Canon MVX250I Mini DV Digital Camcorder
Playback error When I use the camera in play (VCR) mode, it automatic zooms in and stays zoomed in. I have to use the zoom button on top of the camera to zoom the picture out and I have to keep the zoom button pressed. If not, the camera will zoom in again. If anybody understands what I mean, please, help me!
  • Kjellemann Dec 18, 2007
    Thanks for the solution, and you're right..it also zooms in when recording. I will try this solution, although I am not english speaking I think I get the idea :)
    Kjell
  • Kjellemann Dec 19, 2007
    The first solution you mentioned didn't work :(
    I don't have the skill to dismantel the camera more. I'll by a new one, but it might not be a Sony!
    Problem Solver:
  • 6 Answers
I suspect the zoom is also a problem on the camera record also and not just in playback mode. Not certain as to why this happens but I have solved this problem on two MVX250i's by doing the following:
Remove the battery, release the palm strap (velcro) and open the cassette door. remove the two small screws, one in the front and one in the rear of the switch panel holding the zoom button. remove also the two screws it the face of the door cover. Grip the ends of the switch panel with one hand and raise it slightly. At the same time pull lightly on the plastic door cover in a slightly downward direction and the three lugs holding the cover should release. The lower edge of the cover is held with a hook under the metal door and a small metal hook on the lower corner by the strap. The speaker is mounted on the plastic cover and connected by printed cables. Take care not to damage these. The printed cable is attached to the door with an adhesive pad which can be carefully removed and the speaker will then fall from its socket. Close the cover and re-fit the battery. Check if the fault still occurs. On both my cameras the fault disappeared at that point and remained solved when re-assembled. I suspect it to be a poor joint on the printed cables where they enter the sockets at each end.Moving the cables slightly seemed to be the solution. To get to the lower end connection the cassette mechanism has to be parted from the camera. Not an easy job. The top end connection is not easy to access either. When re-fitting the speaker, make certain it is seated correctly in its socket. If it is not then it will short against the metal door.
This operation requires a very small screwdriver, a steady hand and good eyesight/lighting. Re-assembling is never as easy as dismantling so beware. Needless to say I will take no responsibility for these suggestions should it result in your not being able to reassemble it or in your damaging it in the process.
Posted on Dec 18, 2007
Cant change from shoot mode to playback mode.also zoom lens is not adjustable
The Fuji FinePix F470 camera is an excellent device. Most of the controls are computerised in such a way that makes picture taking and viewing less stressful. Changing from shoot mode to playback mode is by the press of the play button which looks like an arrow the zoom lens is not manually adjustable it adjusts by the press of the W and T buttons.
Here is a link to help you download the brochure, User guide and quick start guide for the camera:
http://www.fujifilmusa.com/support/ServiceSupportBrowse.do?prodcat=842410&sscucatid=664271&sscucatid=664272
Hope this soultion has been helpful?
Dec 19, 2010 | Fuji FinePix F470 Digital Camera
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Aug 18, 2007 | Sony Handycam CCD-TRV37 Camcorder
The zoom on the sb600 wont adjust accordingly to the zoom of my lens
Three things come to mind.
First, make sure that you are in fully automatic mode - easily done by reset (holding down "Mode" and "On/Off" at the same time. If you hit the "zoom" button it takes it out of automatic zoom and cycles through manual zoom settings until you get to auto again.
Second - make sure the camera is in an auto mode - manual mode could stop it from zooming.
Third - make sure that you don't have the diffuser pulled down. That can keep it from zooming also.
Mar 30, 2010 | Nikon Speedlight SB-600 TTL Flash
Zoom
Hey bello205,
This camera does not allow the user to actually turn off the optical zoom, but does allow the user to shut off the digital zoom. If you are talking about the digital zoom make sure it is turned on in through the menu system. As far as the optical zoom goes make sure you are not in playback mode. If this doesn't work you can try having the camera reset to the original settings every time you shut off the camera by choosing this option under the setup menu in playback mode. If none of this works have the camera looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 01, 2008 | Olympus Camedia C-720 Ultra Zoom Digital...
Zoom malfunction
I had exactly the same problem. You just need to smash once with your hand on the bottom of your camera (it looks that this works for all canon cameras).
Jan 08, 2008 | Video Cameras
Zoom malfunction
the zoom control button is malfunctioning. try to clean the contact. check the resistant of the variable carbon. if it is not open, try to adjust the contact point away from the damaged area.
Oct 18, 2006 | JVC Handycam GR-DX77 Mini DV Digital...
Optical / Digital Zoom
Press the "T" for telephoto and get closer to the subject. Optical telephoto zoom is like using a telescope to get closer to the subject before taking the picture. With optical Telephoto zoom you can maintain the full resolution and quality. After you have used all of the optical Telephoto range, the camera will continue to enhance the image with Digital Zoom. This enhances the image inside the camera by reducing the resolution and expanding fewer pixels to fill the same image space. Use the "W" Wide-angle button to back-up away from the subject or get a bigger area into your picture. You can even ZOOM IN on a picture in the playback mode for a better look at the details. Turn the Mode Dial to Playback, then press the "T". Use the Enter button to move around the display area. Press the middle of the ENTER KEY to see your images in thumbnail view and / or scroll through several images at one time to find a specific / special image quickly.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
SLIDESHOW function
You can play the images in your camera on a TV or save them to videotape by connecting the camera with the bundled Audio/Video cable. Power up the camera in the PLAYBACK Mode, press the OK/MENU button to open the menu and using the arrow keys toggle up to begin the SLIDESHOW. You can even change the playback format in the MODE MENU. Press the OK/MENU button and using the right arrow key select the MODE MENU. Toggle down to SETUP, toggle right to enter the SETUP MENU and toggle up once to PLAYBACK SETUP. When you toggle right you will be offered four playback options: NORMAL, SLIDE, FADER and ZOOM. When selected you will get the following effects: NORMAL - Each image instantaneously replaces the previous image. SLIDE - The images are sequenced by sliding from right to left. FADER - The images are sequenced via a lap dissolve. ZOOM - The images are sequenced by zooming in to black and zooming out from black.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Difference between the D-400 Zoom and the D-450 Zoom
The D-450 Zoom is an improved version of the D-400 Zoom. Both models have the following features: •1.3 megapixel resolution •3x optical zoom lens - 2x digital telephoto •Stream-lined compact form design •Automatic focus, metering, and white balance •Built-in, pop-up electronic flash •Real-image optical viewfinder •LCD monitor •Buffered RAM memory; burst shooting •Video output to TV •12-second self-timer •8 meg SmartMedia included. Larger capacity cards available. In addition, the D-450 Zoom has the following features: •A larger buffered RAM memory permits rapid shooting (real-time shooting without having to wait for the image write) and a true sequence shooting in more quality modes: Memory Card Storage Capacity Shots Frames per second Quality Mode 10 2.0 SQ 8 0.8 HQ 4 0.8 SHQ •A new high-resolution glare-free LCD monitor screen that can be easily viewed at any angle and even in bright sunlight. The new monitor also uses less power •Automatic ISO adjustment from ISO 160 to 640. Manually selectable ISO 160, 320, and 640 •New Slow-Synchronization flash mode which enables the use of the flash on shots requiring long exposure (such as night time photography) •Image playback now includes an easier to use index mode of 4, 9, or 16 images. A 3x magnification inspection mode allows easy viewing of image detail •Overall power efficiency has been improved. 1.5 to 2 times more battery life compared to the D-400 Zoom •D-450 Zoom comes in a Champagne Gold finish NOTE: The D-450 Zoom digital camera does not include the Olympus FlashPath floppy disk adapter (which was included with the D-400 Zoom). The FlashPath adapter is available as a separate accessory.
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Canon MVX250I Mini DV Digital Camcorder Logo
109 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
