Question about PSC QuickScan 6000 Plus Handheld Barcode Scanner
Need an rj50 scanner lead, was told pin out for the 10 points are: black,-,red,-,blue,-,white,-,-,-. What indicates pin 1 and will it be pin 1 end or 10 end with no wires? If I had two connectors I would make two, one each way. Sorry I have nothing more to go off
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Feb 16, 2017 | Chevrolet Express Cars & Trucks
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
I have a Hopkins Brake Control the pigtail colors are Red, White, Blue, Black. My 2008 Chevy 1500 pigtail colors are Red with a black strip, Light Blue with white strip, Dark Blue, Orange, White. How do i...
1. connect the red wire to the stop lamp switch lead on the brake control. Connect the other end of red wire to the stop lamp switch in the vehicle using the splice connector
2. connect the blue wire to the trailer brake lead on the brake control. Route the other end of the blue wire to the trailer connector at the back of the vehicle.
3. connect the white wire to the ground lead on the brake control. Route the other end of the white
wire to the vehicle’s battery. Use the ring connector to connect the white wire to the battery’s negative terminal.
4. connect the black wire to the power lead on the brake control. Route the other end of the black wire to the vehicle’s battery. Use the fuse assembly to connect the black wire to the battery’s positive terminal.
Oct 22, 2009 | Chevrolet Silverado 1500 Cars & Trucks
I'm just about to have a towbar fitted on a new car for a caravan. I am unsure whether to have a 13-pin socket fitted, as up till now our old caravan and car had just the 7-pin sort for the tailboard and...
Saves having to use a supplementary socket
01 Yellow Left Indicator
02 Blue Fog light
03 White Earth (35amp)
04 Green Right Indicator
05 Brown Right Side Light
06 Red Brake Lights
07 Black Left Side Light
08 Yellow Reversing Light
09 Green Permanent live
10 Blue Ignition live
11 Red Earth (35amp)
12 Black Coupled Trailers
13 White Earth (35 amp)
Aug 31, 2009 | 2007 Volkswagen Golf
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
Towbar wiring
i wiried up my focus estate with the following no relays needed as the wiring is protected by the car fuses
pin 1.yellow/left hand indicator
pin 2.blue fog light
pin 3.white/earth
pin 4.right hand indicator
pin 5.brown/right hand tail light
pin 6.red/ brake lights
pin 7. black left hand tail light
connect these to the car wiring with scotch locks as follows/red/blue.right hand indicator/blue.left hand indicator,green/black,left hand indicator,red/green,right hand indicator,orange right hand light,orange and white,left hand lights, finally green/yellow fog light
hope this is of use to you all my lights are working and correct
May 09, 2009 | 2000 Ford Focus
Reattach Power LED, Power SW, and HDD LED leads
go to the manafacturer website, there should be plans for the motherboard somewhere on there
Nov 24, 2008 | Gateway MS-6389 Ver.1 S462 Motherboard...
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Aug 22, 2007 | Raymarine C80 GPS Receiver
Computers & Internet Logo
71 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
