Question about HP Pavilion dv6000z Notebook
My hp pavillion dv6000 screen keeps going dark although it is set at the highest level of brightness. It is making it hard to see clearly. How can I lighten up the screen?
This seemed to work for me. Newer models of the hp series has a switch
located inside the hinge, so when you close your lid it shuts off the screen. Older models have a button located near the top hinge. By adjusting the brightness using the fn functions (holding fn near ctrl, and pressing f8 at the top) then close the lid till the screen goes dark, then open it. The screen should be set to the adjusted brightness. I think it changes the default brightness, learned through trial n error :-) Hope it works for you.
Posted on Jul 28, 2012
  • 177 Answers
Check your inverter, it's possibly going bad or loose connection
Posted on Sep 24, 2009
Image very dark
go nto the main setting and clear everything and reset it you will have to start from new but the brightness will improve
Apr 29, 2013 | Optoma MovieTime DV10 Multimedia Projector
My hp pavillion dv6000 works but , no light up screen . any suggestions?
If there is an image on the screen, but it is incredibly dark and washed out, then your laptop's back light is out. This is an expensive repair that often exceeds $300. Solutions can be having it repaired, getting it replaced, or using an external monitor with the laptop.
Aug 23, 2011 | HP Pavilion dv6000z Notebook
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
HP Pavillion dv6000 will not load
HP pavillion will not load
if you are able to see the HP logo that tells you that bios is loading but when it gets to the operating system on your hard drive, it can not be located. One of the reasons can be a bad hard drive if it is it needs to be replaced, turn the computer over and check that access covers, one shows you a hard drive logo and it should have 1 or 2 screws, remove those or just loose them up. You may have to stick a tiny flat screwdriver under the cover to pop it off, after you do that remove the screws that hold the hard drive; there should be a plastic or tape tab to pull the hard drive out. Go ahead and pull it out, make sure that the adapter on the hard drive (shiny box) it is properly attached. check the prongs on the computer where the hard drive goes check for dark spots (burn like) if everything looks fine, re insert hard drive (make sure that it makes proper contact) and close the lids turn it on and see if it loads. if it doesn't then you know how to replace a hard drive you just have to have your cds' to load the operating system
if it works for you don't forget to rate me
thx
Apr 27, 2010 | HP Pavilion dv6000z Notebook
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
HP Pavillion DV6000 won't start
It's a fabrication defect. For more info about it and free repair see here
Sep 19, 2009 | HP Computers & Internet
I have an HP pavillion with integrated webcam and
go to video settings and adjust the brightness and contrast and save them. Not in MSN but in control panel or in the webcam SW.
Aug 27, 2009 | HP Pavilion dv2000t Notebook
Hp Pavillion dv6000
Hi
It is indicating battery low. Power is not passing to laptop check power card or adopter....
Thanks
Jul 10, 2008 | HP Pavilion dv6000z Notebook
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
HP Pavilion dv6000z Notebook Logo
552 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
