Question about Dryers
Hotpoint ctd00G will not heat up
My Hotpoint CTD00G Tumble Dryer will not heat up its only giving out cold air, can some help me in solving the proble. I have cleaned all the filters as instructed by hotpoint...
    Genius:
  • 1,036 Answers
This is most likely the thermostat switch or possibly the heating element itself.
One or the other is likely needing replacement.
If you are competent at electrical repairs, and have a test meter; Unplug and move to allow access.
Undo rear top screws and remove lid.
Heating element is usualy on top. Disconnect leads and check continuity of switches and element.
Replace switches with similar if either are open circuit. Available as spares from online parts centres.
Heating element should read in the low Ohms - around 20 - 35 Ohms if Ok, otherwise replace.
ONLY ATTEMPT REPAIRS IF COMPETENT (I have to say that)
Posted on Sep 23, 2009
How to remove top on hotpoint dryer ctd00g
3 screws at the back.........lift up back end then push forwards
cheers
Feb 14, 2015 | Hotpoint Dryers
Hotpoint Aquarius tvm560 tumble dryer is blowing cold Air can it be fixed
sure it can., check ur heating element, with multimeter, and check ur thermostats the hi-lo the thermal cut off , cycling thermostat, etc.
Jan 28, 2015 | Hotpoint Dryers
Hotpoint dryer model DLL2650BFLWH not heating
If this is an electric dryer, your heating coil has broken and is no longer conducting current and heating.
Oct 27, 2012 | Hotpoint TDL15 Electric Dryer
I have a Hotpoint CTD00G. My wife reported to me the drum was not turning on the dryer and there was a smell of burning and when she stopped the dryer and opened it she said it was glowing red hot at the...
this would be the heating element, and as long as the thermal fuse is not bypassed it is all good. You might want to clean all the lint inside(taking the dryer apart) and outside(vent tube) of the dryer, this should be done at least once a year if not twice depending on the usage. The thermal fuse is a safety feature which senses temperature and blows(one time use) thus preventing a fire. Hope this helped Tim
May 15, 2011 | Dryers
My tumble dryer is blowing cold air only. I had a new thermostat put in between 1 and 2 years ago, so hoping it's not that and something else. Can you help me please?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 21, 2011 | Hotpoint Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint CTD40P tumble dryer only runs cold.
hello check the heat sensors first good luck
shaun
Aug 04, 2009 | Dryers
I have a hotpoint aquarius ctd00g dryer.when i turn it on the power comes on but the drum does not spin.
either the motor is stuck or the belt is broken or has slipped off the tensioner.
Jan 26, 2009 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Dryers Logo
238 people viewed this question
Top Dryers Experts
