Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 52 only 2 1/2 years old
When we turned it on everything went fine, the picture was great and then we started getting the vertical rolling. This continued for a while and then the it would start going in and out before going to a blue screen. When reading the other posted problems it sounds like the optical engine is going out. Are we looking at an expensive replacement and time without a tv? So my question to you is, could this problem be due to the lamp?
  • Anonymous Jan 08, 2008
    No picture suddenly, no warning. Teal blue with small grey dash lines over entire screen. Not able to switch to another componet device. No blinking error lights. Unpluged all wires and reconnected. Also, reset with button in front. No change. Help.
  • 4,402 Answers
Hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
TV wont turn on flashing red light
Which light flashes red on the set? Please respond to this same post for assistance.
Feb 11, 2013 | Mitsubishi WD-73C9 73" DLP TV
No sound great picture
Are you connected to a Cable box? then make sure cable box is not on MUTE and audio cables are attached.
From MENU check to see that speakers are not disabled on your TV.
Good Luck
N Sabre
Nov 07, 2009 | Mitsubishi WD-57734 57" HDTV
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Jan 24, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Checkerboard display.
checkboard pattern is generated internally by the light or optical engine.. when the signal is blocked from the signal board. the optic engine generates these test patterns. rolling piture also indicates a signal board problems.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
