GE JTP15 Electric Single Oven
Problem for GE JTP15 Electric Single Oven
As the oven heats up toward the set temperature,
By shdr95 on Sep 23, 2009
As the oven heats up toward the set temperature of 350, it starts beeping and shows the F3 error on the display. What can I do?
Solution #1
posted on Sep 23, 2009
Not Rated)
fixyourboard
Rank: Guru
Rating: 91%, 29 votes
Usually this is a problem with the temperature sensor or it's wiring. Sometimes this is caused by a failure in the control board. If you eliminate the temperature sensor as being the cause (either by measuring its resistance or by replacing it) and it seems to be the control board, then we can help you with that. We fix control boards at www.fixyourboard.com.
Regards,
Bruce
Was this helpful?
Yes
No
Popular Solutions for GE JTP15 Electric Single Oven
Questions and Unsolved Problems for GE JTP15 Electric Single Oven
Do you recommend GE JTP15 Electric Single Oven?
Answer
Answer
the oven makes a horrible noise after it heats up and well after it shuts off. Could it be a fan and... (More)
Answer
It says its preheated to a certain temp but my cakes never seem done when supposed to be
Answer
A couple of years ago I was having F2 errors upon starting the cleaning cycle. I replaced the... (More)
Answer
after cooking at 350 temp for about 3 hours the oven went off with a blank read out window. The oven... (More)
Answer
My oven turned off and then gave error code F3. I believe it is a GE JTP15 Electric Single Oven not... (More)
Describe your Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Oven Experts
Top Range & Oven Repairmen
in Las Vegas, NV
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
