Question about 473L 3-Button Mini Remote
2000 dodge ram. Instrument cluster not functioning. all gauges dead, tach, speedo, oil, etc. all dummy lights on. hi/lo beam ind. ok. blinkers ok. odometer and trip. blank. dealer says remote starter preventing data flow to cluster. any thoughts?
    Problem Solver:
  • 7 Answers
The alarm should not have anything to do with that, but the best way to find that out would be to have the installer hook the factory ignithion and starter wires back up and see if it fixes the problem
Posted on May 13, 2010
Hi,2004 Rocket,6000 miles,riding along lost tacho,speedo,neutral light,indicator warning lights,although they still work,main beam warning light,bike starts&runs ok????
Hi, Nigel I would start at the instrument cluster wiring harness connector made sure you have no corroded, broken or loose pins/sockets and make sure there is a solid ground for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.triumphrat.net/sprint-forum/660602-speedo-tach-light-not-working.html
Speedometer not working sensor
Triumph Rocket III Service Manual
OEM parts for Triumph
Triumph Rocket III Owner Handbook Manual
Jul 04, 2016 | Triumph Rocket III Motorcycles
I have a 2000 dodge caravan none of the gauges work my tack. my temp my speedo and my fuel gauge can you help me how to fix this thanks dean
Check fuse for gauges. If ok, try banging on top of dash above instrument panel to see if they begin to work again. If they do, possible loose connection or defective cluster
Nov 11, 2015 | 2000 Dodge Caravan
The lights for my speedo, clock, temp gauge and fuel gauge not working, indicators, main beam, high beam, oddometer, handbrake, foglight all working ok?
You should have a fuse in the fusebox for the instrument cluster. The instrument cluster houses your gauges, speedometer, clock, and temperature gauge or light. Check the fuse to see if it blown and replace with the same size number on the fuse. Don't decrease or increase the number of the fuse. Stay with the same amp number that is on the old fuse when you replace it. Hope this helps.Good luck.
Mar 07, 2014 | Cars & Trucks
All my gauges quit on my 2003 silverado the dash lights still work but none of the gauges move
Hi, this is a pretty common problem on these Silverado instrument clusters. We can definitely help you out with that. Click here to learn more about these Silverado instrument cluster problems: Dr Speedometer Instrument Cluster Repair Speedometer Repair Guage...
Jan 09, 2014 | Chevrolet Silverado 1500 Cars & Trucks
Where do i start looking for a solution for the following problem o my 2000 dodge grand caravan se?
If you google ( resolder or solder dodge Caravan dash cluster ) you find pictures etc that will make it easier for you. It's actually a pretty common problem around that year. The solder in the cluster where your harness and wiring connector attach (at back) gets cracked and what your describing starts to happen. It's a matter of removing the dash cluster, remove cluster/circuit board from housing, flip it over and just re-heat/re-puddle the spots where the solder is on back of circuit board where that connector attached. If you want more info, feel free to get back to me, but I expect you'll find a good picture if you google it. Good Luck, let me know how it goes.
Nov 17, 2011 | 2000 Dodge Caravan
My 2004 Trailblazer instrument cluster has stopped functioning. The Tach, speedo, oil press, gas, and temp guages spin irregularly and their readings at this point are meaningless. The only things that do...
Hello Mcook389,
If you have above average soldering and de-soldering skills you can perform the repair yourself.
I have repaired many GM instrument clusters and without question this issue is affecting GM instrument cluster all over the country. The particular item that is giving you the bad gauge readings is the stepper motor that drives each gauge.
Please visit my website for complete repair information if you decide to outsource the repair. www.kincerservice.com
Thanks Mike
Jan 25, 2010 | 2004 Chevrolet TrailBlazer
Instrument cluster damaged after battery shorted out.
4 resistors on the back of cluster bad get them at radio shack.
Dec 14, 2008 | 1998 Buick Regal
473L 3-Button Mini Remote Logo
129 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Morgan Kane
Level 1 Expert
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
