Question about Minn Kota Edge 40 Freshwater Bow Mount Trolling Motor
We have boat that came with trolling motor, boat not used in 5 years what should we do to service the motor/minn kota 40at before we put in water we hooked to battery it spun and quit?? not sure what to do we dont have manuel or any experience with trolling motors? need free advice please.
  • 76 Answers
My guess is the motor has leaked water into the lower motor assy (behind the prop). and needs to be cleaned up and the brushes replaced.
here's a schematic:
Edge 40
You can try this to check for water leakage:-
1) disconnect from power supply
2) remove the prop
3) you will see 2 bolt heads behind where the prop was. Remove ONLY ONE of them for now.
4) if you see the bolt (it's about 8" long) is covered in what looks to be blask, oily/watery or rusty condition then you know that you'll need to overhaul it.
5) if it IS the motor assy, remove the other bolt and disassemble everything noting their location.
6) I would recommend replacing the brushes Part# 188-052 and the seal kit 2883460.
Posted on Sep 26, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
    Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
    Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
    https://www.minnkotamotors.com/
    Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
    Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
    probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
    May 15, 2010 | Minn Kota Endura 30 Freshwater Transom...
    Burning out fuses on trolling motor at battery
    not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
    Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Trolling motor doens't work
    I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
    May 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Hook up for one battery operation for minn kota trolling motor
    I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
    http://www.northlandmarine.com/MinnKotaQuickRef.htm
    Apr 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minn Kota Edge 40 Freshwater Bow Mount Trolling Motor Logo
    810 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
