Question about Dual Electronics CECT P168 Cellular Phone
I can't speed dial with my f003 cell phone. On the user manual shows about it, but I can't find it on the menu. Please, help, it's too boring having to dial or look through the phonebook every time I make a call... thanks
  • milanH Dec 18, 2009
    I also have the speed dial problem with my f003. On top of that, I can't set my incoming calls ringtone to either Silent or Vibrate. Does anyone know how to fix this please help! Much appreciated!
How do i change my voicemail number?
Press phone/menu/settings. Is the speed dial for your voicemail showing correct in there? If so, and you are still reaching the wrong number, contact sprint and explain to them what's happening. It's possible your default vmail number has gone a little screwy in the number change.
the place to check your speed dial is phone/menu/speed dial.
Apr 27, 2014 | Blu Zoey T176 Unlocked GSM Dual-SIM Cell...
Hello, I am trying to set up speed dial on my panasonic phone and I can't seem to fid the instructions in the manual book. My Panasonice phone has 4 phones and I think the serial number is KX-TG6034. ...
menu, contacts, scroll to contact , edit, assign speed dial. If that doesn't work go online to your carrier's website and download the pdf manual for your model. Panasonic might also have what you need.
Mar 20, 2011 | Cell Phones
No manual for i9 3g+ phone
u can by links off ebay for 1 $ and their really good i got 1 for my i9 f003 and they had everything for the phone including games and apps.
Jan 16, 2010 | Lands Phones
Internet on f003 phone
go to main menu, wireless,search for networks, and choose your network, connect,then enter your password. If you want the phone to permenantly remember this connection you can do this by editing the acces point settings. If you want to use wap (the slower service your phone provider offers, but will charge you for) you need to set this up by getting the codes from your sim provider.
Once you are connected you can go back to the main menu, and choose the internet browser of your choice (I run opera mini on my f003). you should then be able to browse as normal.
Sep 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Mi F003 show the error NOT ALLOWED TO DIAL tis is a video of the error: http://www.youtube.com/watch?v=bhJj21J6z_M Thank´s
Guys I had the same problem with the k599 Sciphone and none of the solutions found on the internet helped me. New chinese models tend to restart after testing is over and this results in turning the wifi application on. So I spent many hours on thinking how to bypass this function and this morning I woke up with an idea that really worked!! The steps are quite similar with the ones followed to debug older models:
put 2 chips on cell
Disable WLAN.
1-enter in factory mode *#3646633#
2-go to RF Test Tool
3-choose GSM, confirm OK!
4-go to Power scan
5-Select Band DCS1800 click OK
6-the cell frozen
7-wait for 3 minutes testing
8-while testing connect to a pc using the USB cable (do NOT select ANY of the options appearing on the cell screen)
9-Click the CENTER button of the cell until you go back to principal menu
10-go to settings/network settings and choose GSM Preferred or any other option (except WLAN only!!)
In this way the cell does not reboot, and the wifi application stays off, so the option can now be changed...
Hope this helps!
Greetings from Greece!
email me to akiss_bd@hotmail.com if any questions
Jun 30, 2009 | Dual Electronics CECT P168 Cellular Phone
Speed dialing
There are two types of speed dial and the programming varies with the system you have.
System speed dial is programmed from the operator or manager's phone or PC and they reside in system program 001.
Personal speed dial numbers reside in my system at location 10.
You can try PROG 10 and see what the display says.
The user manual has instructrions for programming personal speed dials.
Carl
Aug 27, 2008 | Panasonic KX-T7731 Corded Phone
SETTING SPEED DAIL
Dear rugrats
Please find below the direct download link to the user manual of the V360 phone (PDF file - 5.4Mb Download)
http://www.motorola.com/mdirect/manuals/V360_9495A85B.pdf
At page 45 & 46 you will find detailed information on how to setup the speed dial function of the phone.
Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
Mar 01, 2008 | Motorola Mobility V360 Cellular Phone
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
290 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
