Question about New World G60m Gas Single Oven
Ignition spark won't stop clicking - New World G60m Gas Single Oven
  • New World Master
  • 8,220 Answers
The small spark switch on the oven control must be defective. remove a wire from that switch and see if the ticking stops. be careful not to let that live wire short against anything, including you. LOL
Posted on Sep 23, 2009
Ignitor on stove won't stop clicking
Contact a professional to have the ignition diagnosed for replacement. Do not use the unit before then for safety reasons.
Aug 25, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Whirlpool super capacity 465 gas oven that won't stay lit. It often lights up the first time just fine but then it turns off which is normal but when it tries to relight itself the ignitor...
That sound to me like yall have some carbon buildup on the igniter. On this stove the igniter does 2 jobs. It lights the burner and verifies back to the control that Houston we has ignition. If junk is built up on that ignitor then she won't be sending verification of ignition back to the control. That white residue needs to be removed. NOTE: I don't have your model number I am going by what you describe that this stove is a Direct spark ignition model. If you have a normal ignitor it probably is weak and not drawing 3.5 amps to open the valve. Post a model number (bottom drawer frame)
More Here
Sep 08, 2011 | Ovens
We have a Whirlpool Gas Range, model SF357PEKQ. When I start the bake feature, you can hear the gas flow, the ignitor click (about 4 times) yet there is no ignition of the gas (flame doesn't start)....
Whirlpool had some grounding issues with some of their electronic ignition ranges. Make sure your outlet is grounded first. Then you might need to make sure the bake burner itself is grounded very good against the range frame. I have put star washers between the burner and frame and tightened very tight, that sometimes helps. Also make sure the holes in the burner under the spark electrode are clear from debris. Sometimes the burning of gas leaves a residue that can stop up the holes and not let the gas flow out where the spark is hitting the burner. Hope that helps.
Aug 29, 2011 | Ovens
Ignition switch seems to be jammed - ignition spark on continually
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Dec 12, 2010 | Ovens
Igniters will not stop clicking.
Hi
Thanks for using FIxYa.The igniter doesn't stop clicking due to a short inside the igniter circuit or due to moisture present on the ignition switch.Turn off the gas supply immediately and also unplug it from the mains power. Now take a blower or your hair dryer and blow hot air over the igniter. Also check for the following troubleshooting steps---
1) The gap between the igniter and the burner base is too large. *Should be approximately the thickness of two dimes.
2) Soiled igniter or burner base.
The above can be tested by switching the suspected burner with a known operating burner.
3) Loose wiring connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched igniter wire between the burner and module.
Both of the above are physical inspections under the main top.
5) The module may have a week coil, which is not providing sufficient voltage to ignite the gas.
Even after performing these steps the igniter doesn't stop clicking then you need to replace the spark module.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
The bottom oven on my stoves cooker ignites but then constantly clicks and will not stop until the gas dial is switched off. Can any one give me a clue as to why? Thanks
As an ex stoves enginneer, the problem may be one of three faults;
1. cracked electrode, what creats the spark in the oven
2.electrode lead has melted.
3. faulty ignition generator.
Try takin the lead off the electrode and placing it in the oven flame, if this stops the clicking, then replace the electrode.
L.B
Jun 10, 2009 | Stoves Ovens
Ignitor problem with gas oven
The spark ignition coil is failing. As this is an oven, it can be dangerous not to have a strong ignition spark. A gas buildup in the oven could cause an explosion.
You should replace the spark generator coil which is located at the back of the oven and is usually orange/black or blue in color. Ariston usually use ITW Ispracontrols ignition coils.
Mar 26, 2009 | Ovens
Electronic ignition system failed
electric ignition. Electric goes to ignition button, then to a spark generator, where upon a spark is produced. If any part of this sustem is wet, then it is shorted to earth. No spark.
Feb 11, 2009 | Bosch HBN 131560B / 131520 hot-air...
VulcN MODEL gc04C CONVECTION OVEN WON;T IGNITE ER-05 CODE
Like an electronic igniter for a gas grill? I believe you can pick up a replacement. Call Lowes or Homedepot. I know i have saw individual igniter's before my friends bought some for my friend and I when we were little to make potato cannons.
Jan 22, 2008 | Vulcan GCO2D Gas Single Oven
New World G60m Gas Single Oven Logo
493 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
