Question about Bassett Cottage 3-in-1 Crib
I have a bassett crib model 5927 0521 how do I convert to a toddler bed?>
SOURCE: converting crib into toddler bed
Call customer support @ 18002951980 and customer support can either email or fax instructions at no charge. I just did it and got the instructions myself. Or you can email me @ shannaboxley@yahoo.com and I'll foward the instructions to you.
Posted on Jun 20, 2008
SOURCE: Jardine Crib 4 in 1
step 1: detach the front panel (part j) from the front posts h(1) and h(2) using allen wrench
Step 2 if mattress support (part K) is not in the lowest position, unscrew mattress support bolts (Part d) from the post and move it to the lowest position
Step 3: Using the wrench provided, attach the guard rail (part f) using 4 bolts (part a) between the left and right front posts
Step 4: tighten all screws clockwise.
good luck
Posted on Oct 24, 2008
SOURCE: Bassett Southampton Crib Directions
THE DIRECTIONS FOR BASSETT SOUTHHAMPTON CONVERTIBLE CRIB (model 5925-0521) ARE LOCATED *INSIDE* THE WARNING LABEL ON THE WIRE CRIB BASE. The warning label is an envelope that holds the direction packet. I was confused, too--I thought they hadn't included them with my crib! Hope that helps!
Posted on Jul 06, 2009
SOURCE: Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
Posted on Jul 18, 2009
  • 78 Answers
SOURCE: converting from crib to toddler bed
It is very simple to convert a crib to a toddlers bed. You just need to remove the side railings by folding them under the bed. It would be automatically converted to a bed that a toddler can use please might you rate me or vote for me
Posted on Mar 04, 2010
Bassett crib model 5530-0621 purchased in 2007- how to convert to day bed? Currently have it set up as a crib
If you don't have the rails to convert, Bassett discontinued the crib in2008. You can convert it using a standard metal (bolted) frame found in mattress or furniture stores. I called customer service today and found this information. 7/15/2013
Sep 05, 2011 | Bassett Baby Gear
Converting from crib to toddler bed
Mar 03, 2010 | Baby Gear
Bassett crib model 5665-0621S. How does it
you can try asking at manualfox.com
Jan 20, 2010 | Bassett Baby Gear
Model Number: 5542-O521 Does this convert?
It does not convert to a toddler bed. I had a custom front piece made to make one. With on the side rails and no front legs, it's only useful initially as a baby bed. I am now looking to fond the side rails to make a double bed out of it myself. I'll look for the name somewhere and try to post it for model 5542-O521.
Oct 24, 2009 | Bassett Cottage 3-in-1 Crib
Converting a crib into a toddler bed
what brand and model number of crib/bed is it?
Jun 13, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Need instructions ofr converting crib to a toddler bed.
This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
www.milliondollarbaby.com/help.milliondollarbaby.com/
*For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
*For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
For cribs with Safety Glide nylon(rodless) hardware
Sleigh Convertible 3001 Crib
Sleigh Convertible 3091 Crib - Safety Glide
Jenny Lind Crib
Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
Ashley/Alexandria Crib (3-piece headboard) +Day bed info
Lauren Crib ) +Day bed info
Emily Crib (One piece headboard) ) +Day bed info
Emily Crib (Four-piece headboard) ) +Day bed info
Mini Emily Crib
Anastasia Crib
Bridget Crib
Valerie Crib ) +Day bed info
Bailey Crib ) +Day bed info
Ellie Crib Day bed and full bed info
Kalani Crib Day bed and full bed info
Bordeaux Crib Day bed and full bed info
Annabelle Mini Crib
Italian Cribs-Metal Barrel Nut
Italian Cribs-Nylon Nut
Canopy cribs with snap-in spring hanger hardware
Canopy cribs with metal bolt-in hardware
May 16, 2009 | Bassett New Haven 3 N 1 Crib
Convertible crib directions
there should be a sticker somewhere on the furniture that tells you exactly which set you have. from there you can either email them or call and they will send or fax the instructions. hope that helps.
Aug 03, 2008 | Baby Gear
HOW DO I ACTUALLY CONVERT A 3 in 1 CRIB TO A BED?
I have two children and I changed their beds from the cribs to the day beds by taking the front or footboard part off.  You have to save this part because in order to change it from the day bed to a full bed, you have to buy a siderail kit, take the sides off, and attach the siderails to the headboard and footboard.  Hope this helps!
Oct 11, 2007 | Bassett Cottage 3-in-1 Crib
Bassett Cottage 3-in-1 Crib Logo
190 people viewed this question
Top Bassett Baby Gear Experts
Jennifer Rock
Jennifer Rock
Greg Cann
Greg Cann
ray gallant
Are you a Bassett Baby Gear Expert? Answer questions, earn points and help others
