Question about Maytag Washing Machines
Maytag Preforma spins out of control
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have a Maytag Performa HD “Quiet Series” 4 speed 16 cycle top load washer, Model # pav3300aww Serial # 1275577yy. We purchased this wash 6 or 8 years ago. I retired recently and became aware that my wife is making additional trips down stairs on wash day. The machine agitate the close to one side than on spine it’s out of balance and sounds like a train wreck, it gets so bad that if she doesn’t run down stairs to catch it it will vibrate across the basement floor to the end of the hoses. She contacted a repair person a year ago who came over and freed up the self leveling devices but it mad no change. I worked 12 to 16 hours a day 7 days a week and rather than bother me my wife just dealt with the problem by running up and down the stairs. I’m not so inclined to do that. I’ve made sure the machine is level , No help, I’ve leaned and lubed the self levelers’ and they work fine No help, I even set the front legs in a 2X4 that I nailed to the floor and the machine broke lose and ran again. If on ever load we wait until the machine has completed agitating (the close not me) and than re-disrupted the clothing it will spin out okay but it still spins unevenly. This problem happens on large, small, heavy and light loads alike and in ever incident all of the items in the wash have been agitated all to one side of the drum before the spin cycle begins. Thank you for any help you may offer.
Ken
  • Maytag Master
  • 2,355 Answers
A couple of thoughts:
1. Take top off and check to make sure springs/absorbers are in place and not broken..
2. Try a load with no clothes and see if it happens.
Good luck.
Posted on Feb 27, 2017
  • 177 Answers
SOURCE: I own a Maytag Performa
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Posted on Jul 12, 2008
THENTHEREWER
  • 131 Answers
SOURCE: Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Posted on Nov 16, 2008
SOURCE: Out of balance
Installed no slip carpeting underneath machine, worked fine.
Posted on Feb 16, 2009
  • 14 Answers
SOURCE: Maytag Top Loader Thumps When In Spin Cycle
My guess is that one of the three counterweights have separated from their support. Probably rusted away.
36 years is quite a feat. Today's machines would be lucky to 1/3 of that life.
Sounds like its time to go shopping.
Do you have an anniversary coming up?
Ladies love washers for an anniversary gift.
Posted on May 24, 2009
burdfrenzy
  • 348 Answers
SOURCE: Kenmore Series 80, Model: #23822 Type: 3.
You have a bearing going bad. most times its not worth the repair. Go to Sears online and they can help
Posted on Oct 15, 2009
Spin Cycle is slow
new belt or there is a thrust bearing above the drive pulley that wears out.
May 22, 2010 | Maytag PAV2300 Top Load Washer
Could you please tell me how to remove the agitator for cleaning on a Maytag top loading performa machine heavy duty.super size 3 speeds quiet series 100 13 cycles Thank you Bob Clark bobgc@bigpond.com
The agitator on a Maytag Performa comes off by removing the center post cap and dispenser by pulling on it. Locate the agitator bolt and loosen (you may need to hold the agitator in place while loosening). With the bolt removed, the agitator will lift off.
If you still have questions, please let me know. I hope this helps you.
Sep 16, 2009 | Washing Machines
Spin cycle does not complete and there is a small water leakage and an error is shown DC
Hello tmsn2tree,
See this post for the details on a DIY repair for clutch issues with this machine, post back if you have questions. Most DIY folks can do this it's just a tight work area and you will save yourself $350+ in parts and labor. Your machine is a series 17 first two digits of your S/N mine is a series 16 and did not use the upper oneway roller clutch bearing. If you DIY the repair I would like to know if your series 17 machine has the upper roller clutch bearing. Rich
May 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My maytag washer model PAV3300AWW will not spin
Check the belt at the bottom of the machine. You can also remove the back panel. Either the belt has become stretched or broken and needs to be replaced
May 22, 2009 | Washing Machines
Burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
Jan 23, 2009 | Maytag SAV5710 Top Load Washer
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
261 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
