Question about Roper RAS6233KQ Top Load Washer
Cant get back off Washer
Am trying to take the back of the washer off so i can get to the pump to check it out and see if it needs replaced. Am having difficulty--any suggestions?
Is it a direct drive washer? If so then the back doesn't come off. You can take off the outside housing very easily. Just locate the 2 screws on the back top corners of the washer. Remove them then flip the control panel backwards. Unplug the lid switch and remove gold clamps by prying them up with a screwdriver. Then just lift off the housing---the pump should be right in the front.
Posted on Jan 13, 2008
How do i replace a washer pump in a 98 tahoe.? Where is the pump? Thanks
hi, the washer pump is located in the bottom of the washer bottle that you fill up you may need to get to this from under neath the car.
if you have a look at where you fill the washer bottle up and follow it to the very bottom you will then see the pump if you have rear wash as well then you will have 2 pumps one for front and one for the back.
now if you cant hear the one pump working then the chances are the pump needs replacing if they both dont work then i would check fuses first, if you can hear the pump work but no water comes out then give the water jets a good poke with a pin and this should get them working
if you do need to replace the pump get to the bottom of the washer from under the car and you should then see the pumps in the bottom of the bottle now you need to pull the wire connectors off they are only a push fit and then to get the pump out you need to twist it out the pump is only pushed into a rubber bung in the bottom of the washer bottle so its not held in by bolts or screws its just a push fit.
if you buy the new pump first you will see what i mean about it being a push fit once you have the old one out just push the new one in the replace the wires and rubber hose and then give it a try.
if you have any problems give me a shout back ok
Aug 20, 2010 | 1998 Chevrolet Tahoe
Volvo v50 washer fluid doesn't spray
Hi, their are a couple of common problems here.
but first of all check the following.
can you heat the pump come on when you press the button for the washer, if you cant hear it from in the car open the bonnet and get someone to press the button and listen for the pump if you hear it then you know the pumps working if you dont hear anything then the pump needs replacing.
if neither the front or back windows work and the pumps make no sound for front or back washer then your next stop would be the fuse box, check all the fuses and replace any blown fuses then try the washers.
If how ever you can hear the pump working then the problem is going to be one of 2 things the most common is going to be that the water jets are blocked to unblock them get a small needle and poke into the holes where the water comes out of then try the washer, if it still dont work then the problem is the other end at the washer botlle, you will find the pipe by the pump has gelled up due to the cleaning fluid you put into the washer bottle so what you now need to do is remove the washer bottle and the pumps and give the pipes a good clean out to ensure they are not blocked.
i hope i have given you some things to check
Jun 28, 2010 | 2005 Volvo V50
Water not draining away after cycle
Hello Friend,
It seems like your machine is neither Pumping nor spinning, that is why it is unable to drain the water out. In this case you should check the pump. Your washer probably has a frozen pump pulley. If so you need to replace it. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Give it a check. Do get back to us if you need any further assistance.
Thanks
Mar 05, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Water not comeing out of washer front r back cant hear pump sound
check the wiring to the washer pump - its on the bottom of the washer bottle, disconnect the connector to the rear washer pump (do them both) and clean up the contacts with sandpaper - you can try swapping the connectors over and see if the front washer connector will power the rear washer, if so the problem is a fuse or the rear washer switch is broken.
Tell me how you get on and I'll advise further.
This way you can prove both pumps work, if the rear pump wont work off the front pump cable then the pump is at fault and needs replacing.
Jan 25, 2010 | 2003 Hyundai Tiburon
Washer will not drain water and is leakiing from
HI, this leak is caused by the back up or clog in the drainage system. use the following text to troubleshoot this issue.
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 11, 2009 | Frigidaire CWS3600AS Top Load Washer
Wiper Fluid Not Spraying
First of all-Check ALL of your Fuses. Inside the Reservoir there is a Small Pump. This is the Pump that you need to replace if no Fuses are Blown.
Jan 12, 2009 | 1999 Chevrolet Suburban
Need to replace pump/spin belt
this washer your have to take the 2 1/2" bolts on each side the motor then you will have to take 3 star bit screws out of the bottom of the pump slide the pump off then put it all back together and then after mounting you motor and pump back up put it on the transmission puller
Dec 31, 2008 | Amana ALW480DA Top Load Washer
Frigidaire Glet1041AS Pump Drain replacement
washing machine is leaking from the bottom left what could this be
Nov 08, 2008 | Frigidaire GLET1041A Top Load Stacked...
LD light
umm. thinkin perhaps something flaoting around on the drain pump house perhaps causing partial restriction of drain capability.new pump doesnt maen something cant get struck in impeller
Oct 30, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Roper RAS6233KQ Top Load Washer Logo
37 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
