Question about NorStar M7310 Corded Phone
I know how to set the time but, it won't display or "keep" the correct date or time on our system
  • george  peters
    george peters May 11, 2010
    Does it default back to jan. 01 or does it lose 15 minutes or so after a while?
  • Anonymous Mar 17, 2014
    Since time change time is not correct on display how do I reset it
    Problem Solver:
Make sure your hitting the Change softkey, after entering hit next,
Also, make sure that you have appearence showing on the extension number.
Posted on Sep 30, 2009
Setting the date and time
After selecting 1, type in the date mm/dd/yy (it doesn't appear on the screen) then press hold/save. Then type in the time again it won't appear on the screen press hold/save. It will then return to the main screen with the correct time and date. Hope this helps.
Oct 16, 2012 | LG Ericsson LIP-8012D 12 Button IP Phone
How do I change the Date and Time displayed?
You log into the Phone administrator settings, Go to General, Select Date and Time and correct them for the entire phone system.
To Log Into System Programming:
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
3. Press: NEXT Display will read: "B. General Admin"
4. Press Show
5. Select Date and Time and Press Show Correct Date and Time then press release. Let me know if you have any other questions.
May 16, 2011 | Meridian M9316 Corded Phone
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 | Watches
How to know if the battery of the motherboard is empty
use multitester to check the battery of the cmos..
set the multitester to DCV 10..
and watch out for the pollarity of the battery..
Mar 18, 2010 | EliteGroup ECS GF6100-M754 Motherboard -...
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
IN 120 base keeps flashing CL
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Jul 09, 2008 | Lands Phones
Visys time/date display settings will not stay correct - help please!
I have the same problem. I cannot believe I wasted $70 this stupid phone. No more RCA ever.
Jul 07, 2008 | RCA 25404RE3 Corded Phone
Time
This should take care of it for you.
NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
  1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
  2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
  3. Press the [Start / Enter] button.
  4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
    NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
  5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
  6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
  7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
Dec 13, 2007 | Office Equipment & Supplies
NorStar M7310 Corded Phone Logo
82 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
