Question about Refrigerators
Freezing up, frig not cold, freezer working. 567 lit up on freezer temp adjustment
  • 4,070 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Sep 23, 2009
FGHB2844LF water dispenser not working
Turn the temp down on the refrigerator side but not below freezing. Some frigs have a "trap" set up for the water dispenser. its located behind a panel in the frig and it is there to help chill the water before it dispenses. if the frig setting is too cold then it can freeze the water .
Dec 08, 2013 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
Frig is turned down to low and everything is still freezing. Ice maker not making ice.
icemaker not working because to cold in freezer;water transfer tube frozen and will need to be deiced, but first must solve refrig. to cold, making freezer to cold, thermostat problem which is common it is a presure filled and in time can loose presure and will run colder, some have adjustment scew with arrows warmer or colder adust warmer and only turn a 1/4 turn or less until you get in middle of dail range. or replace thermostat. refrig. temp. should be 38 to 40 degrees frenhiet. freezer no colder then 0.
Nov 29, 2009 | Frigidaire GLRS234ZA Side by Side...
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
Items in frig freeze
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Here's a diagram of your fridge controls and parts.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177055&diagram_id=1347585#d1347585
Oct 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
My dometic refrig is freezing everything what is the problem? the freezer part works great but also freezes the the bottom frig part also-
Oct 18, 2009 | Refrigerators
Frigidaire Refrigerator FRS26H5ASB5 side-by-side
Hi, yes, your thermostat could be faulty, yes there should vent( damper), check controls on freezer side, controls amount of cold air going to ref. side, yes could be stuck by ice, yes both adjustment are necessary, check manual, some thermostat are very sensitive, you should adjust gradually, wait for about 40 minutes, before adjusting again. yes there's vent flap (damper) yes that could be your problem, normally they get stuck with ice, remove covers to locate it., you 're smart, you will see, damper, good luck.
Aug 12, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frig is not getting cold at all and the freezer is not freezing Thanks
Hi, I can help you. What brand & model# is this? Is there any frost built up on the inside rear freezer wall
Vic
May 27, 2009 | Freezers
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Whirlpool Freezer doesn't freeze?
insulated or not, garages are generally too cold for new energy efficient frigs to operate. ambient temp needs to be above 60 to work efficiently.
Mar 07, 2008 | Refrigerators
Everything in frig is frozen and it won't turn off.
If the compressor is running non-stop then the temp. control is not telling it that it's "cold enough". If the compressor isn't running non-stop then you should look at the air damper (little window) that lets the freezer air into the refer compartment... if it's stuck open then you will always get cold air pushed into the fridge eventually becoming a freezer in itself.
Jan 17, 2007 | Kenmore 74844 / 74842 Top Freezer...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
