Question about Garden
John Deere LX188 lawn tractor battery discharge light remaining o
John Deere LX188 battery discharge light came on when I started the mower. It's remaining on, while I mow, even after I've now given the battery a full charge.
    Sniper:
  • 197 Answers
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Posted on Nov 13, 2009
  • 389 Answers
If you have access to a volt meter, with the engine running at full RPM check the voltage at the battery terminals. It should read around 13.5 to 14 volts. If it is just showing 12 volts or even less, your charging system is at fault. In this case I/we would need to know which engine is in your tractor (MAKE-MODEL-SPEC#) While you are taking the voltage reading also check your battery terminals for corrosion and tightness.
Posted on Sep 23, 2009
How to remove the old lower hood on a john deere lx178
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
JOHN DEERE LX172 LX173 LX176 LX178 LX186 LX188 LAWN GARDEN TRACTOR Service...
Apr 29, 2017 | John Deere Garden
I have john deere lx188 rideon mower when i engage the pto the engine cuts out.
This sounds like a seat micro switch problem, make sure the block connecter is fully home and the switch depresses when you sit in the seat, if all else fails replace the switch
Dec 09, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
Lawn mower blades won't budge, even w/ 1/2' drive impact wrench
Hi, warm the nuts up with a heat gun or oxy torch then try the impact gun while they are hot, regards Phil.
May 31, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
How do you remove mower blades on john deere lx188
Get yourself a rattle gun connect it to an air compressor with the right
size socket hold the gun on reverse it should remove the bolts.
Apr 22, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
John Deere LX188 17hp Kawasaki eng. Battery light constantly on; PTO for mower intermittent; will shut down after running for about an hour(battery discharge?). Suspect voltage regulator. Can't...
I have same problem with my lx188 battery light stays on and will run fine at idle, then I can mow for about 15mins then it powers down and run rough, and battery light dims down.
???? Is it the voltage regulator ?
May 06, 2011 | Garden
I HAVE A JOHN DEERE LX188 MOWER. 17 HP. GOVENOR NEEDS ADJUSTING.
Your engine per John Deere is a Kawasaki FH500V
Here is the service manual (3.58 Mb pdf file) This should get you going again.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Jan 23, 2010 | Garden
I have a Deere LX188 mower, while mowing the
you need to check the seat switch first then have the park brake switch looked at.is there power to the starter relay?
Jul 23, 2009 | Garden
Discharge indicator light stays on.
I would start with a new voltage regulator which is located under the battery tray.
Jun 16, 2009 | John Deere Garden
John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
May 08, 2009 | Garden
Garden Logo
1,115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
