Question about Acer Aspire 3680 Notebook
Wireless switch on front of unit does not work-metal slide is missing. How can I jump the swirch?
  • 80 Answers
if your not able to replace the hardware part ,here is the alternate way.
disable the wireless adapter whenever you dont require it by : right click on my computer - propertys - hardware - device manager - network adapters - there you will find wireless adapter - right click and disable it. short cut to open from run command: sysdm.cpl
Posted on Sep 23, 2009
Testimonial: "many thanks, I assumed that the wireless would not work with the switch inoperative. Am I correct, that the wireless defaults to the "on" position? "
Icemaker 106 626133 in 1987 Whirlpool ED22MMXRW sid-by-side
Happy to report that I now have a working icemaker. I had to replace the control module--just replacing the gear was not sufficient. The wiring was slightly different for the new module because it had a side connector instead of one coming out of the lower left corner, but I was able to use front metal plate plus its attachments (motors and switches) of the new to replace the similar parts on the old.
Jul 16, 2012 | Whirlpool Refrigerators
My Minii was given to me a a gift recently, no matter what I do I am una.ble too make an Internet connection It;s a Wireless connection I want, but all I get is a big red X and a comment, make sure your...
Please refer to the User Manual for the HP Mini Netbook, located here:
http://h10032.www1.hp.com/ctg/Manual/c01657997.pdf
Specifically, take a look at page 25, "Connecting to a wireless network". At the bottom of this page, if you are seeing the icon listed as Wireless (disconnected), this means the wireless switch on your Mini is turned off. To turn it back on, find the small slider button on the front of your Mini with the wireless antenna icon next to it, and slide it. This should activate your wireless card, and if you have a wireless network in range it should identify it shortly after.
If your wireless card is already on, and it cannot find your wireless network signal, you can try either (1) restarting your router, or (2) visit the HP Support page for the Mini 1115NR, select your version of Windows installed on the Mini, then download and install the latest wireless networking drivers.
Mar 01, 2011 | HP Mini 1115NR Netbook
I was changing a light bulb with one of those metal extension rods that unscrew and screw back in the replacement bulbs. It evidently didn't seat correctly and pulled off the bulb and created a quick...
If you have not already done so, I would check at the fuse or circuit breaker panel to see if you have blown a fuse or tripped a breaker.
Aug 28, 2010 | Vacuums
My wireless capability switch is turned off on my acer aspire 5532 where is the button to turn it on?
wireless capability on my acer laptop is a switch that you toggle on the front of the computer.
I suspect that you just need to slide the switch over and release to turn the light on for WiFi and also to turn the WiFi capability on.
Jun 30, 2010 | Acer Aspire 5570-2758 Notebook
Turning on wireless
Slide switch on front edge, make sure it's switched on.
Jun 09, 2010 | Toshiba Satellite M115-S3154 Notebook
Where is the wireless switch on this dam thing
Some laptops don't have a mechanical switch for wifi. But just try to look around the back portion or the front or sides of your laptop. Wifi switches are slide type. You just slide it to toggle on and off.
However, newer laptops have no mechanical switches. To turn your wifi on/off, just hold down the FN key and press the Function Key (F1 to F12) where you can see the wifi logo like this: )))
In my unit, it is FN+F10
Try it out.
May 22, 2010 | Acer Aspire One PC Notebook
How do i turn on the wireless switch?
Most of the time it's a sliding switch on the side toward the monitor or the front of the laptop. It's also usually easy to miss.
Apr 29, 2010 | E-Machines M5414 Notebook
88 ford ranger ignition cylinder frozen i need it 2 turn 2 remove
Take the plastic cover from around the steering column. There's a small hole under the lock Inside the hole is a small button you need to push in on which should release the lock cylinder. The key has to be in the switch. If that doesn't work, theres a thin metal rod that goes into the electrical of swirch. You need to remove it than try to turn the key. Than push in on the little button while trying to remove the lock .
Feb 07, 2010 | 1988 Ford Ranger
Hyundai grandeur 99 model-can't find relay/module for rear brakes
WHICH GLOBES (BULBS)? I presume Brake Lights? The circuit is a DIRECT CONNECTION at the brake SWITCH (brake pedal arm). If all your fuses are good, then I'd begin to suspect the brake lamp switch is defective.
Jun 05, 2009 | 2001 Hyundai XG300
Wireless not working
I assume it's a laptop/notebook.
If so then there is a switch near the light that is on when the adapter is on. It will be a very small slide switch, on the front or side edge. Simply find it and slide to on. Or if it's already on then try pressing the fn key and f8 together, as this sometimes is a second wireless switch.
I hope this helps
May 09, 2009 | Computers & Internet
Acer Aspire 3680 Notebook Logo
150 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
