Question about Olivetti wireless All-In-One InkJet Printer
I have an Olivetti Any_way printer-the colour cartridge has plenty of ink is clicked into place properly but the the PC is not not seeing the Colur cartridge and will not print-help
Same problem @@!#&@7 printer
Posted on Dec 08, 2009
Same problem **** printer
Posted on Oct 14, 2009
Why does the blue colour turn out red on printing plus the yellow is mainly pink?? I am trying to print out invites for my son's 10th birthday & he is not impressed with the pink!!
See if the ink cartridges are installed correctly. It may be that your Magenta and Yellow ink cartridges need to change places. So, try replacing the cartridges, put the Magenta where the Yellow is, and the Yellow where the Magenta is.
Usually the ink cartridge placement follows this order:
Cyan, Magenta, Yelow, Black, so see if the cartridges on your printer match. Also, check to see if there are color markings on the print-head itself, and make sure the markings match the cartridge inks.
If the ink cartridges are aligned properly and the Black is printing out just fine, you may be looking at a software issue, and you'll need to remove the printer from the Devices list (go to Start -> Control Panel -> System), unplug the printer from the PC and restart. Then, install the drivers first, and after that plug in the printer cable to the PC.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Jan 28, 2011 | HP Office Equipment & Supplies
Can ip1300 print with just black ink cartridge?
AS far as I know you cannot put a black cartridge in the place of a colour cartridge it has to be a colour one. Check your printer properties to see if you can set your printer to work in black only, if you can then set it to black but leave the empty colour cartridge in place. This works for my 1800. Give it a try.
Aug 05, 2009 | Canon PIXMA iP1300 Printer
Printer will print with almost no ink on page in colour or b/w
You have to have both the cartridge installed and then
Run a nozzle check to make sure the nozzles are clean. Try running a printer self-test to make sure the printer is running properly without using the computer.
Macintosh 9.x or earlier: Open the File menu and choose Print. Click the Ink icon. You'll see a window showing the ink remaining in each cartridge.
Macintosh OS X: Double-click the Applications folder on your hard drive. Double-click EPSON Printer Utility, select the C42 Series printer in the Printer List window and click OK. Then click the EPSON StatusMonitor button. You'll see a window showing the ink remaining in each cartridge
May 04, 2009 | Epson Stylus C42UX InkJet Printer
False colours
Not being very familiar with this printer but if it has a calibration test/option I would run it and make sure it is set properly
Nov 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Colour cartridge has run out and printer won't print.
Hi
Realy sorry but the only non new purchase option I have occsionaly found to work is to pull the colur cartridge and reinstal without using.'
Another one I've heard of and would definately not recoment is if you have an old recharge kit top the colour up with meths. My opinion of this is a great way to destroy your print head and cartridge.
Rewcharge kits containing all of your colours are inexpensive if a littlebit messy do it in the laundry or bathroom, over newspaper and preferably with a pair of gloves.
Kind Regards
Nov 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
No color--plenty of ink
the colour ink must be dried up.so its not printing.replace the cartridge to make it proper.
Oct 23, 2008 | HP PSC 1610 All-In-One InkJet Printer
My printer, a Lexmark 1300 series USB printer, will not print in black ink. It has plenty. The ink is proper lexmark ink. It just appears to not be looking at it's black ink cartridge at all as when I put...
Check your printer preferences and be sure that you're printing in the right way. Select grayscale and see what's happen.
Delete all printer pending jobs.
Take out the cartridge, turn off the printer and wait 5 min.
Turn on the printer, insert the cartridge and try again.
If nothing happens, replace the cartridge
You will find more info here:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569478_0_en,00.html
Oct 09, 2008 | Lexmark Office Equipment & Supplies
Hp dj3745
it means either there are pending documents in the print que delete them,if no pending documents remaining in the printque.
then either of the print cartridge is faulty.remove the cartridges 1 by 1 and check and see whether its blinking .
if the blinking stops after removing black cartridge the blck is faulty, or if,the blinking stops after removing the colur cartridge the colour is faulty.
if still blinking then both the cartridges are faulty.
thanks.
Sep 16, 2008 | HP DeskJet 3745 Printer
It thinks the ink cartridge is not installed, but it is
It's because you touched the connection side of the cartidge. Clean it with some contact cleaner(or surgical sprit)and let it dry.If possible clean the printer side of catridge contact.After both are dried well, put the catridge back.it must work.
Aug 03, 2007 | Canon PIXMA iP90 Mobile Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Olivetti wireless All-In-One InkJet Printer Logo
249 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
