Question about Refrigerators
My rangemaster fridge is not dispensing ice anymore what should i do to fix it, when i press the botton it doesnt come out
  • 11,896 Answers
Try lifting the bar that moves on ice box. If moving this bar has no affect on the machine turning on and off, then the circuit that is attached to it is faulty. You can get manual and parts at repairclinic.com
Posted on Sep 23, 2009
I think i damaged something with the hairdryer while trying to thaw my water in the door
An overheated solenoid will only affect the ice dispenser not the water section so we can rule that out. I would render a guess that the dispenser paddle is broken or melted. This would prevent the microswitch from making contact with the paddle. Replacing the paddle should fix the issue but you will have to verify.
I assume you have a GE fridge based on the frozen water line issue. Instead of heating the area with a hair dryer i have had great luck with this little trick. Purchase a container of "zoom spout oiler" which can be found on amazon. Empty the oil into a suitable container and flush the residual oil out with water. Next time it freezes fill the zoom spout oiler with hot water and extend the nozzle inside the frozen line and squeeze. I also disconnect the water line behind the kickplate under the freezer. Lock the dispenser so you don't accidentally pour water on your floor. Put a towel on the floor and when you clear the blockage at the dispenser water will flow onto the towel. Hope this helps you with your fridge!
May 04, 2017 | Refrigerators
Switches on kitchen aid refrigerator dispensers not working.. ice maker is working, but will not dispense ice or water
Sounds like the water has been turned off, or the solenoid valve (located at water entrance to fridge) has failed. you should hear a solid snap from that solenoid when water is called for by pressing the dispensing switch. You can test the solenoid by unplugging the fridge and measure the resistance across the solenoid terminals. If it measures 200-500 ohms it is ok. if it measures open the solenoid has failed and needs to be replaced.
Sep 18, 2014 | KitchenAid Refrigerators
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Water and ice have stopped working from front of fridge
I assume the freezer is making ice, that it just won't dispense.
Most likely a solid-state controller has gone bad. No fixing these controllers... Must be replaced.
Less likely is the switch that you trip when you press on the arm to dispense ice or water.
Aug 22, 2009 | Refrigerators
I have a GE side by side fridge. Model # GSH22VGRBWW It does not make ice. We was purchasing bagged ice and putting it in the ice dispenser tray and we could get ice now it will not release the ice. You...
Remove the ice bin,with the freezer door open ,press the pin switch at the top of the door opening, then press the ice dispenser ...if the forks on the auger motor rotate its ok... if they dont the motor is frozen
Jun 28, 2009 | Refrigerators
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Admiral Fridge Freezer
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
Jul 12, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice doesn't dispense and both freezer and refrigerator aren't cold enough
yes. pull out the frig and look on the back. facing the back on thr right hand side there a rectangle metal plate. under that plate is the main computer board that controls the whole thing. they have been causing alot of problems one of which is the one your having. replace that board and your problem is solved
Nov 26, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Nov 07, 2006 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
499 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
