Question about Toshiba Satellite A100-S8111TD Notebook
My lab tob can connect to a wireless network but couldnot access to the internet it says(access point :local only) how can i fix it?
  • Scott Burrow May 11, 2010
    You need to go to a unsecured access point, not peer to peer network (it looks like 2 computers) They usually don't have internet access.
  • Pal
    Pal May 11, 2010
    hi, Does it work fine with ethernet cable? if yes could be in issue with wireless security key. if your sure that it is correct, uninstall and reinstall wireless adapter once.
  • 591 Answers
You need to configure access as "Private" in order to access Internet.
Posted on Sep 23, 2009
Tip
How to set up the PS3 Internet Connection
This setting is available only on PS3 systems that are equipped with the wireless LAN feature.
The following procedure describes a typical setup when connecting to the Internet wirelessly.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Confirm that an Ethernet cable is not connected to the PS3™ system.
3.
Select (Settings) > (Network Settings).
4.
Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
5.
Select [Easy].
6.
Select [Wireless].
7.
Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option Automatic. Select Automatic when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
8.
Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
9.
Check the SSID for the access point.
10.
Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
11.
Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12.
Save your settings
13.
Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
14.
Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
on Mar 09, 2010 | Video Game Consoles & Games
My ipv4 says that there is not internet access and my ipv6 says there is not network access
Try this:
While connected to the PC in the cmd window netsh /release. once the V4 IP address reads 0.0.0.0 type netsh /renew in the cmd window this will give you a valid IPaddress.
Good Luck!
Aug 01, 2012 | Cisco Linksys WET610N WirelessN Bridge...
I have windows 7 home prem and cannot connect says detects strong signal but limited access
Most likely, the access point is not connected to an internet gateway whatever that is at your place.
and since access points does not provide DHCP service by default (handing out IP information to connected clients), you get the limited access message.
In short, make sure the access point is connected to the router because the router is the once responsible for providing the DHCP service.
Feb 18, 2012 | ASUS WL-330 802.11b Wireless Access Point
My wireless network connection status in connected Speed is11.0 and my signal strength is good, but I cannot connect to the internet connection godd but internet explorer cannot display the webpage
You are getting local access only.
Right click on the icon in the system tray and click repair....
If it still happens you need to connect to a different network..this usually happens if you are connecting to an unsecured network (I assume yours).
Alternative: Unplug the network adapter. Turn off the computer. Wait approx 2 minutes.
Power on computer with net adapter connected....
Dec 18, 2009 | Sony Computers & Internet
Sitecom WL-330 range extender with dlink dir-615- unable to use
I am guessing you have XP or vista. here are the instructions for both.
XP 1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Double-click Network and Dial-up Connections icon, double click Local Area Connection, and Local Area Connection Properties window will appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Vista 1. Click the ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Click View Network Status and Tasks, then click Manage Network Connections. Right-click Local Area Network, then select ‘Properties’. The Local Area Connection Properties window will appear, select ‘Internet Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Next step for both All functions and settings of this access point must be configured via the web management interface. Please start your web browser, and input ‘192.168.0.234’ in the address bar, and press the ‘Enter’ key. The following dialog should be shown: Please input user name and password in the field respectively. The default user name is ‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web management interface of this access point: NOTE: If you can’t see the web management interface, and you’re being prompted to input user name and password again, it means you didn’t input username and password correctly. Please retype user name and password again. After you connected to the access point by web browser, the first thing you see is ‘Status and Information’ page. All system and network related information of this access point will be displayed here. The information is very helpful when you want to know the detailed information of your access point, and when you try to fix the communication problem between this access point and other wired / wireless computer / devices. You can click ‘Home’ on the left, This access point can be operated in different modes; you can click ‘Basic Setting’ to select an operating mode you want to meet for different needs: You can click ‘Mode’ dropdown menu to select operating mode, and there are 3 operating modes available: AP Access point mode, allows wireless clients to connect to access point and exchange data with the devices connected to the wired network. Station- Infrastructure Enable the Ethernet device such us TV and Game player connected to the access point to a wireless client. Universal Repeater This product can act as a wireless range extender that will help you to extend the networking wirelessly. The access point can act as Station and AP at the same time. It can use Station function to connect to a Root AP and use AP function to service all wireless clients within its coverage. You can hopefully figure it out from there.
Sep 13, 2009 | D-Link DIR-615 Wireless Router
Cannot connect to internet
you might need to reinstall the driver for your wireless adapter
Do these steps
-shut down your computer
-reseat your wireless adapter back to PCI slot
-turn on your PC
-Your PC should be able to detect your wireless adapter as a new hardware
-put your driver CD back to install your driver.
tada ..
Mar 24, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Ps3 help
This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
1.
2.
3.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings) in the home menu.
4.
5.
Select [Easy].
connectwired002.jpg 6.
Select [Wireless].
connectwireless001.jpg 7.
Select [Scan].
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
connectwireless002.jpg 8.
connectwireless003.jpg 9.
10.
connectwireless004.jpg 11.
connectwireless005.jpg When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
12.
Save your settings.
13.
14.
Hints
  • If the connection fails, follow the on-screen instructions to check your settings. Also refer to the information from your Internet service provider and the instructions supplied with the network device in use.
  • If you test the connection immediately after selecting [Automatic] > [AOSS™] in step 7, the router settings may not be completed and the connection may fail. Wait approximately 1 or 2 minutes before testing the connection.
Jan 30, 2009 | Sony Playstation 3 (PS3) Console
I cant get my ps3 to work with my wireless broadband
Settings > Network Settings > Internet Connection Settings (wireless connection)
Internet Connection Settings (wireless connection) This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
1.
2.
3.
4.
5.
Select [Easy].
Select [Wireless].
Select [Scan].
10.
12.
Save your settings.
13.
14.
Hints
Mar 12, 2008 | Computers & Internet
CGA5722 - Boxed in "A
can you a little bit describe what other device that you are using. maybe access point. Are you using an access point?, or switch?
Feb 15, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
