Question about Konica Minolta Magicolor 2530 DL Laser Printer
Toner Not Installed
I have recently refilled the cartridges with replacement toner but now the printer status window states that each toner is not installed. I have cleaned the inside of the printer thinking that it is a sensor problem. What is the issue and how do you solve? Thanks.
  • 2 more comments
  • billnot Jan 19, 2008
    I have exactly the same problem. I have cleaned the printer and the cartridges, and ensured they're properly installed. Nothing seems to work.
  • hodapp8 Feb 25, 2008
    I have the same problem~ I have replaced them all with Minolta brand heavy duty toner and all of a sudden it says that they're not installed and the error light comes on and the printer won't print!  Cleaned all.... WHAT THE HECK???  HELP!
  • Anonymous Feb 25, 2008
    Same problem. Printer was 2 times in Konica / Minolta for repairs. They say that the sensor was broken..... Now i got same problem 3rd time.....&%^$#$%# i will just change printer. In this problem sensor is not detecting cardriges but printers software shows how much toner is in it. Junk
  • jmh64 Feb 29, 2008
    Same problem: "Black toner cartridge not installed" error message. Nothing seems to fix it.
Yay! That fixed it!!! Thanks nightangel. You saved me a service call and lots of inconvenience.
Posted on Mar 01, 2008
    Champion:
  • 214 Answers
Its a typical problem for these printer.
turn off printer
remove pc drum and toners
under the toner rack you'll see a 3 reading pins, clean it, best way to clean it is using pressure air bottle.
reinstall everything.
Posted on Feb 29, 2008
How do you reset counter on Toner for TN-360
No, If you use a refill in your recent toner cartridge you need to reset the toner, if you use a new toner cartridge, no need to reset.
Aug 28, 2014 | Brother MFC 7840W Printer
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
Kyocera FS-2020D adding toner screen will not shut off
It is normal to do this "adding toner" operation aprox. 20 minutes. You have to wait until the printer enters in "ready" status. Take a little brake and relax, your printer needs to refill the developer unit with toner dust from the cartridge.
May 10, 2012 | Office Equipment & Supplies
I refilled toner of my Lexmark E120 (since it said it was out of toner) and it worked fine untill few days ago when I got status report: Missing or defective catridge. Could this mean it's out of...
Replace the chip, is a chip cartridge problem.
if not work try this:
31 Defective toner cartridge or missing cartridge
1. Verify that the toner cartridge and PC kit are correctly installed.
2.Wait 10-20 seconds for the printer to verify the units.
3. Replace the toner cartridge or PC kit if necessary.
Aug 01, 2011 | Lexmark E120 Laser Printer
Hello sir i want to know the details of cartridge if it shows the status " The Toner is exhausted replace the toner" is there any chance to refill that one or replace it please give reply.
It depends on the Model of the printer and cartridge number. You can't refill all the cartridges. If you let me know the model of your printer and the cartridge number, I think I can help you how to refill it and how to open it apart.
Thanks.
Aug 30, 2010 | Office Equipment & Supplies
HP color laserjet 1600 wonte printe new toner color.
The supply status report is based on what the kill chip is reporting to the printer. If that particular color is not printing then it is likely that current is not flowing though a particular component in the cartridge. I would return the cartridge and get a replacement.
Feb 02, 2010 | HP Office Equipment & Supplies
OKI B4400 toner - is the chip reusable? I get toner not installed
The chip is not reusable and needs to be replaced every time. You should be able to find a chip on the internet somewhere. I own a Cartridge World printer cartridge refilling store and I do not recommend refilling your own toner cartridges or buying super cheap ones off the internet. The toner is generally such a low grade that it degrades your drum cartridge causing you to replace a $219 drum unit before you should have to.
Jan 27, 2010 | OKI B4400 Digital Mono Printer - Black
CLP 300 toner cartridges invalid toner
the drum has chips encoded,need cartridges with chips.
May 29, 2009 | Samsung CLP 300 Laser Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Konica Minolta Magicolor 2530 DL Laser Printer Logo
221 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
