Question about Water Heaters
I turned my heatin on the about an hour later there was no heat the ingnition light is not on tried turning it off at the wall but starts up then goes quite again any help please
    Champion:
  • 248 Answers
Relight pilot light refere to manual check fan faulty fan causes lockout
Posted on Oct 12, 2009
Why does my bosch 25e ingnite then blows out repeatedly and occasionally stays on if i turn tap on and off and on for abit.
Does the unit have a flame sensor? Check manual. Flame sensors get corroded and need cleaned or replaced. I have had success cleaning them but when you can buy a new flame sensor
Apr 25, 2014 | Bosch Water Heaters
Electric Pool Heater Tripping Out!
What is the model number of the unit?
Jul 13, 2013 | Water Heaters
How do I troubleshoot a 6kw 240 volt circulation heater. This heater is on a baptistry; they fill it up before service starts and use it 90 to 120 minutes later and water is still cold.
It is very possible that you just are not giving it near enough time...
I have worked on them before and they do not heat the water very fast....
you will need to give it at least 12-24 hours to heat the baptistry properly...
That heater will only heat about 30-35 gal./hour....on a 50F rise in water temp. ....figure how many gallons you have there and then do the math...
heatman101
Apr 13, 2011 | Little Giant Water Heaters
Drained water heater but forgot to turn off heating element. was on for about 12 hours
there is a possibility that the heating element is now burned up, you can refill the tank and try to heat water,, if the water is not getting hot then I would say that you need to replace the element. also check the circuit breaker and wall outlet for power just incase the element did blow the fuse.
c...
Dec 31, 2010 | RTO Atwood Water Heater - 6 Gal LP
No hot water coming out. ignition comes on ,but no lighting of gas. There is gas in bottle and it's on as normal.Works one day , doesn't the next.I cannot remember if there was a pilot light before!
check for pilot but im sure that the pilot is on demand thats what makes these things so cool and inexpensive to operate. try having someone turn on the hot water while looking for ignition. if there is nothing it may be a relay. im not sure but if you open it up check for a 3 amp fuse its green. all the new furnaces with mother boards have a fuse. I am not really a heating guy but i have been looking into on demand systems and sat in a training session at the plumbing supply. never hurts to try and help.
if its not a fuse or the ingniter isnt functioning you may need to call a heating person who knows on demand or check Bosch on line maybe they have the trouble shooting guide if you dont.
sorry that all i can suggest hope it helps
Dec 04, 2010 | Bosch & Tankless LP Hot Water Heater
Rheem model #GP40T6PF00 lp hot water heater Will
sounds like one of the saftey relays might be going bad. or the ingniter might be cracked or need cleaning
Mar 08, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Noticed that pressure was low today on Greenstar 42CDi. Filled up to 1 bar only to see an hour later that it was back on zero. Turned heating off, blead all rads (some air released but no water??). Re...
there are air in the system let it out til you get water in the release outlet fil up to 1,5 or 2 bar no problems wil started also control the expan ballon for bilding and expanding the pressure
Dec 20, 2009 | Bosch Water Heaters
My water pipes froze thursday night so friday night when i went to bed i left the tubs hot water turned on and they thawed out about 2am i got up and turned the tub faucets off the water was hot at that...
you probibly ran the hot water tank out of hot water shut off the hot water comming out of your fausets for a few hours and check it again u could also try to reset your tank by pulling off the front cover and hitting the reset button and my last thought is sadly you burnt out your heating elements and they need to be replaced good luck man
Feb 28, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
I have a power vent2 water heater by Rheem products. Problem seems to be with blower fan turning on when thermostat calls for heat. Fan makes un-able to start noise and thermostat stops. If I turn the...
your blower motor is trying to seize up on you, it is time to change it, if the fan doesn't come on first your water heater should not light, the fan comes on first to get eccess gasses out of the burner compartment,, do not light with ot the fan first it could combust
Jan 27, 2009 | Bosch & Power Vent Water Heater
Pilot lights (not always) but gas will not flow into burner
First Clean the ignitor assembly and make sure the flame is reaching the flame sensor strongly.
You may need to replace the flame sensor.
Sep 19, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Water Heaters Logo
65 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
