Question about Samsung SGH-e315
How do i turn on my red touch of color on my
How do i turn on my red touch of color on my LN52A630
I have a 5 yo 52" Samsung lcd.From a cold start it cycles on then off about 6 times before a picture comes on.I replaced capicitors and no difference. Whats next?
Most of the time only secondary large electrolytic capacitors are being renewed althoug small E. capacitors in a primary circuit of an smps (around the switching driver IC) can also cause this kind of issue. Although you say you replaced them i still believen its a bad capacitor.
Jan 29, 2015 | Samsung LN52A630 52-Inch 1080p 120 Hz LCD...
Canon LBP 5300 color problem
You seem to have done all the obvious things. Time to get in touch with Canon Support I think!
http://www.canon-europe.com/Support/
Jan 28, 2014 | Canon LBP5300
51F59A red screen all the time
1. entire grill below front screen must come off (usually held in place by screws in back on either side.)
2. locate and remove inspection plate dead center behind it.
3. Locate small black plastic block with 6 black controls built in; three (look carefully) left to right are focus--DO NOT TOUCH THOSE.
The other three are Screens and will be marked with tiny letters r g b (red, green, blue) and green is always middle.
Locate the red screen (not FOCUS).
With set on adjust red down just slightly(usually less than 1/8 turn.
Since the set will be on TAKE CARE NOT TO TOUCH ANYTHING INSIDE THE SET WHEN YOU DO THIS.
IF YOU HAVE QUESTIONS ASK BEFORE YOU TRY THIS.
Nov 20, 2011 | Hitachi 51F510 51" Rear Projection...
Gray turning red when colored.
You have to look at it as if your grays were blonde, it's going to have a red hue to it as if a blonde were to dye it the same color. I suggest using a gray touch up in a darker brown tint first and then dying all of your hair a day or two later. This should prevent it from turning red and give you a color that is closer to what you're looking for.
Feb 12, 2011 | Revlon Colorsilk Hair Color 4N Medium...
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
I have a color stripe from the top to bottom on the right center.
It is panel related problem if you can open LCD than open & clean all connector properly & refit properly.
Jan 23, 2010 | Samsung LN52A630 LCD TV
TV 40'' Samsung LNA630 Touch of Color
the touch of color is not a function, it's the red tint on the plastic cover
Dec 28, 2008 | Televison & Video
57H81 Red Bleeds, Dull Color, Was Pink
change the l.c.d colour corretion board new £ 400 not worth doing in my opinion part hard to get i stopped reparing these 5 years ago . agro agro agro ebay part not good these sets have a horrible short life
Dec 08, 2008 | Toshiba 57H81 57" Rear Projection...
Wiring problem
yes that is right, color to color turn of breaker before touching wires. green and bare copper go together.
Nov 01, 2008 | Jenn-Air JED8430 Electric Cooktop
Touch Screen Error
RED GUN OK, you need convergence IC's replaced = Toshiba
part # STK392-110T.....................................T.
Nov 14, 2007 | Toshiba 50H82 50" Rear Projection...
Samsung SGH-e315 Logo
131 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
